Old 12-28-2015, 12:55 PM   #11
nodrawers's Avatar
If its not another GFI, take the CB panel cover off and tighten the screws on the CB's that clamp the wire. They can and will vibrate lose.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
nodrawers is offline   Reply With Quote
Old 12-28-2015, 02:39 PM   #12
Somewhere there is a junction box tying those outlets together and powering them. You may need to trace out the wiring.
Harkerr is offline   Reply With Quote
Old 12-28-2015, 02:52 PM   #13
Lost gfci
Possible to have three gfci's? Bathroom, kitchen,& basement. Good luck. 😎
MrLucky is offline   Reply With Quote
Old 12-28-2015, 03:35 PM   #14
Not sure if this model has it, but some outdoor kitchens have a separate GFCI outlet.
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 12-29-2015, 11:21 AM   #15
thanks for all the suggestions. The owner is getting a schematic from FR and will be trying to trace out the wiring to see what is the problem. I do appreciate all the suggestions given and hope he can figure it out.
aydodster is offline   Reply With Quote
Old 12-30-2015, 09:51 AM   #16
Go to the first outlet, the GFI. Should be two cables. One supplies the power to the GFI, the second powers the next outlet. Make sure it is hooked up properly and all the termanals are tight. It may not be hooked up right to supp;y power to the second outlet. If everything is OK then go to the second outlet and make sure there is power coming into the outlet. If the first is good but no power at the second then you may have a broken wire, but that would not be common.
The GFI is normally the first outlet in line and most likely the one with a problem. Often they are not wired properly and can be working but not supplying power to the next if not wired right.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 12-30-2015, 09:59 AM   #17
well it turns out the three outlets are fed off the refrigerator breaker and they are separately wired back to the main box. Factory thinks there is an issue with breaker and the owner is going to replace that in next couple of days once he can locate it. I have passed along all the suggestions to him and appreciate the quick and thoughtful responses from the community. Thanks Patrick
electrical
