Old 12-27-2015, 06:24 PM   #1
3010DS some outlets not working
My next door neighbor at Carrabelle RV park has a 2014 3010ds which has developed an electrical issue that I was wondering if any others out there might have seen. Three outlets on driver side are dead. Those on passenger side are working fine. No power to any of them and the GFCI in the bathroom is set and working fine. The breaker at the panel is ok and seems to be functioning for those outlets on passenger side.
Each outlet has single power line coming into the back. Opened all three and nothing seems amiss there. Not sure where to look next and he has spoken to the dealer where he got it and they are stumped too. So anybody out there that might seen this before? Thanks Patrick (2013 3107DS)
aydodster is offline   Reply With Quote
Old 12-27-2015, 06:39 PM   #2
Mr. Dan's Avatar
There "might" be another GFCI outlet somewhere. I hear some units have 2.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 12-27-2015, 06:48 PM   #3
well there is one in the bath and I will see if I can poke around tomorrow and see if there is another one somewhere. It will not surprise me that there might be another. Thanks Patrick
Old 12-27-2015, 06:48 PM   #4
A32Deuce's Avatar
X2! I would turn off and on again the circuit breakers. I have found they some times loose contact and act up. Have seen it in garages and an Rv is similar in the fact hot/cold lack of use.
2012 SunSeeker 3100SS Toad-1962 Futura
A32Deuce is offline   Reply With Quote
Old 12-27-2015, 06:57 PM   #5
they have done that particular action multiple times with no results. The solution remains elusive. They are planning on taking it in at some point and hope the techs can figure it out. Thanks for your suggestion. Patrick
Old 12-27-2015, 07:05 PM   #6
Flybob's Avatar
X2 on second GFI.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-27-2015, 07:07 PM   #7
thanks.. went over and found just one. Will take a longer look tomorrow.
Old 12-28-2015, 11:57 AM   #8
BobHanke's Avatar
There could be a second GFI in a basement compartment for outside use and linked to some inside outlets???
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = Shikibu
BobHanke is offline   Reply With Quote
Old 12-28-2015, 12:30 PM   #9
The GFI may be bad have you removed the outlet and checked if you have power to it. I had a GFI go bad in my house and had to replace it. My 3010DS GFI is in the bathroom. You can contact FR and they can email you a wiring diagram I got my the next day after my request. Good luck
edcronin01 is offline   Reply With Quote
Old 12-28-2015, 12:44 PM   #10
good idea on the wiring diagram. I will pass it on to them. Best I know they have power into GFCI in bathroom and it seems to be good.
electrical
