Old 06-24-2016, 01:48 PM   #21
My old 5-wheel was 30 amp. New one is 50. Had 30 amp plug with 30 single breaker. Put a 50 amp plug in, replaced single 30 amp breaker with 30 amp double. Marked the cover as such (so I can remember). Only use for storing at home.
mikebecker80 is offline   Reply With Quote
Old 06-24-2016, 02:42 PM   #22
Ideally run 10 Guage for 30 amp, 6 guage for 50 amp.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 06-24-2016, 03:26 PM   #23
Yep, 10 gauge for 30.
Old 06-25-2016, 07:58 AM   #24
Since your trailer has 50A service, you'd be best off using a 50A outlet. The problem is running wire to it. If you installed 1/2" conduit, the maximum number of #8 wires you should run in it is 3, one less than you need for a 50A outlet. 3/4" conduit will easily take the four #8 wires needed for the 50A outlet. If you're limited by the conduit size and don't want to replace it, Use #10 wire with a 30A outlet and use an adapter for the rig.
I see no problems running 50A wiring and using a 20A breaker. You can always easily change the breaker at a later date if necessary. You should also put a label in the outside box indicating that the outlet is on a 20A breaker.
Phil
pmsherman is offline   Reply With Quote
