Old 02-10-2013, 05:05 PM   #11
Originally Posted by garbonz View Post
Hmmm. Interesting. If that is true, then it may be in the adapter wiring. And you'd pop he breaker if both were on. There also is a gizmo that you can wire to a 30 amp circuit that will cycle two AC's on so that only one runs at a time and they switch so that the coolness is distributed better. So there are different way of doing the 30amp to 50amp thing, I suppose.
We popped the breaker for all sorts of reasons but knew enough not to run both A/Cs. The water heater was our main culprit when running other stuff. A baby bottle warmer was our second biggest consumer/problem.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
ependydad is online now   Reply With Quote
Old 02-10-2013, 11:12 PM   #12
Thanks for all the help , my new trailer is a palamino puma 39ptd park model and has 50 amp. service , but at the seasonal camp ground i'am at has 30 amp. hook up.
Brian10 is offline   Reply With Quote
