Old 03-20-2015, 09:37 AM   #21
Canadian Member
itat's Avatar
Definitely confirm the voltage before plugging your trailer into the outlet.
Hopefully the electrician left enough slack in the cables to allow you to install the proper box.
Old 03-20-2015, 09:37 AM   #22
Herk7769's Avatar
Originally Posted by Ddubya View Post
Most 30 amp RV boxes have a cut out on the bottom to allow the cable to recess into. That allows the plug to mate with the socket without the cable hitting the bottom of the box.
Sounds like the wrong box was installed.
Which should be a BIG RED FLARE that the wiring is wrong too.
HAM CALLSIGN - KC3FFW
Old 03-20-2015, 09:50 AM   #23
TURBS's Avatar
I know this is a "tad" off topic but undoubtedly worth mentioning.
I'd consider installing a progressive industries ems surge guard in your camper so there's never an issue of bad or wrongful wiring.
Old 03-20-2015, 10:03 AM   #24
geotex1's Avatar
Actually, that flare, to me, was the fact of the orientation of the mounting altogether. An electrician knowing what he or she is doing, knows the proper orientation of a receptacle for its purpose. The cover jammed on it (OP removed) actually has a cord outlet (though would never fit an RV or any 30A cord) and it is oriented opposite of where it should be. Even a few years ago, that installation wouldn't fly for several reasons, and not just because of an in-use cover.
OP, I would encourage you to have it properly sorted by an electrician over just making do. There's also nothing wrong with proper DIY, but you should have an inspection to satisfy your HO insurance should ever the worst happen.
geotex1 is offline   Reply With Quote
Old 03-20-2015, 10:41 AM   #25
Ret E-9 Anchor-clanker
donanddona's Avatar
Seams a lot of users would offer up an "easy" fix. At what you have offered up, and with your genuine concern I would like to say this. When I had the electrician install the power in the garage for my camper I knew I would love camping. Right now I have a 5th wheel but I might, later in life want to upgrade to a 50amp A class. The electrician told me for an additional $75.00 he would install a breaker box. The plan was to only have a 30amp plug. He put a breaker box in and told me, when I was ready he would take the 30amp plug-in back and install the 50amp plug for an additional $50.00, I'm not there yet but who knows what will be in 3-5years. I feel confident that I will have safe power when I need it and at this time the $75.00 was well worth it. Oh, did I say "if" I want to install additional receptacle's it is also available too.
donanddona is offline   Reply With Quote
Old 03-20-2015, 01:13 PM   #26
Jeffco, MO
tedstr's Avatar
30 amp Outdoor Box
I used a 30 amp RV Outdoor box that had a circuit breaker. The instructions were very clear on how to hook up. Box was at Home Depot.
I used the box with the circuit breaker because it was suggested to always hook up with the circuit breaker off at the campsite. I also turn the circuit breaker off before I disconnect. The reason I put a circuit breaker in the box on my home site was I did not want to go inside my house and basement to our house circuit breaker box. I also added a line just for the outdoor box using the correct gauge wire for 30 amp. This way you are now sharing the line with other items.
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
tedstr is offline   Reply With Quote
Old 03-20-2015, 01:36 PM   #27
It is a very good idea to turn the breaker/disconnect off and not plug in under any kind of load...
Joe
meganjoe is offline   Reply With Quote
Old 03-26-2015, 09:38 PM   #28
Mr. Dan's Avatar
Here's how my 50a box looks with attached power cord.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 03-27-2015, 05:53 AM   #29
davel1971's Avatar
Find a new electrician and get an actual RV outlet box. I got mine from Lowes
David & Lynn
Old 03-27-2015, 07:27 AM   #30
Ddubya's Avatar
No need to do 50amp unless you plan to run more than one A/C unit at once.
Ddubya is offline   Reply With Quote
