Old 04-25-2012, 07:55 PM   #11
Triguy's Avatar
I get it now
(and I didn't even drink anything tonight).
So, the top illustration from the 12volt side would be better represented as this...
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-25-2012, 08:02 PM   #12
Herk7769's Avatar
By George I think WE got it!
HAM CALLSIGN - KC3FFW
Old 04-25-2012, 08:07 PM   #13
Triguy's Avatar
Yea, two pages later. Now I'm really tired
Scott
2012 Shamrock 233S
Old 04-25-2012, 08:33 PM   #14
Originally Posted by herk7769 View Post
The idea is that the current "path" from the camper's postive to the camper's negative should be as equal in length and resistance as possible THROUGH EACH CELL of the batteries in the bank.
Eggs-Actly!!!!!!!!!
[When I get my TT road worthy, I plan on two
6 volters, so I get to use the trivial case.]
cheers,
johnd
2001 Cherokee CKT27X - 2005 Chev 3500
Sara, John & Crafty Canines - Coco and Cole
Medical research shows that men have a "biological clock" too. The older we get, the greater the NEED to drive a TRUCK!
dnaraG_1M is offline   Reply With Quote
Old 04-27-2012, 03:04 PM   #15
I understand the advantage of using two 6 volt batteries in series but I don't understand how the converter can recharge/maintain the batteries. Does the series wiring also halve the input voltage of the converter to charge the 6 volt batteries?
2008 F-250 PSD 4X4 Pullrite SuperGlide 15K
2012 Crusader 290RLT Touring Edition
Cascade Bob is offline   Reply With Quote
Old 04-27-2012, 04:26 PM   #16
Triguy's Avatar
No. From a power standpoint, it helps if you think that a "bank" of two 6-volt batteries that are wired in series is the same as one 12-volt battery.
When charging, the converter "sees" only one 12-volt battery.
Scott
2012 Shamrock 233S
Old 01-02-2016, 08:25 PM   #17
Does anyone have a picture showing 4 6 vold golf cart batteries actually installed in a Cedar Creek 36CKTS? CC suggested I do this but two dealerships have told me there is not enough room.
mecapeman is offline   Reply With Quote
Old 01-07-2016, 08:01 PM   #18
racer4's Avatar
mecapeman,
You can measure the box and compare to the size of the batteries.
In this thread, Who installed 4 GC2 Batteries in their 36CKTS? the 36CKTS was not originally built with a residential refrigerator and the battery box was not big enough for 4 GC2 batteries.
The pictures I have seen, the GC2 batteries in a 36CKTS sit side by side, right to left, 4 in a row.
I measured the battery compartment on a 2015 36CKTS with a residential refrigerator. It was about ~28-3/4" W x ~11" D .
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually, 4.10 axle, Auto Flex Air Ride Rear Suspension
2017 Cedar Creek 36CKTS, Disc Brakes
racer4 is offline   Reply With Quote
battery
