Old 05-16-2016, 10:21 AM   #1
CWSWine's Avatar
45 Amp Adapter
I was given on of these for free, has anyone used one? Seems it is cheating and getting a cheaper 30 amp site for your 50 amp 5er, before I use it I would ask the park owner.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 05-16-2016, 10:24 AM   #2
elrand's Avatar
I have one that has 2 30amp connections to make the 50 and use at the perm site i have my trailer in my space has 2 separate 30a connections but no 50 so it lets us use both our AC's
2015 Cedar Creek Silverback 33IK
elrand is offline   Reply With Quote
Old 05-16-2016, 10:28 AM   #3
They make dogbones that go directly from 50a to 30a because there are a lot of places that only offer 30a service. It's not cheating.
If anything, you're only cheating yourself because you aren't able to use your RV to it's fullest capabilities.
Iwritecode is offline   Reply With Quote
Old 05-16-2016, 10:32 AM   #4
They also don't work with GFCI outlets. I bought one years ago because the 50A breaker was bad and it was a way to run our rig but it didn't work because of the GFCI ... dang it!
It's sitting in the basement of the house collecting dust.
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 05-16-2016, 10:36 AM   #5
CWSWine's Avatar
What this is suppose to do is plugs into a 30 amp and 15 amp on the poll and make it 45 amps. By the reply above it may not work at all sites. One of those things you carry because you may need it but just adds to the weight of the 5er.
Old 05-16-2016, 10:44 AM   #6
You might be able to fool the GFCI by using a 15 amp 3 prong to 2 prong (with external grounding lug) adapter. Not an electrician nor would I recommend it. But have been curious to know if it would work.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 05-16-2016, 10:44 AM   #7
CWSWine's Avatar
I just check Amazon description of the adapter and says it will NOT work with GFCI outlets. I haven't really paid that much attention to the 15 amp plugs but I bet most of them have GFCI since they are out door plugs.
Old 05-16-2016, 10:57 AM   #8
dieselguy's Avatar
They were handy several years back, but with most any RV pedistal at any park having a GFI now days ... they are a thing of the past. It'll trip the GFI instantly. Wiring around it isn't worth getting kicked out of the campground.
dieselguy is offline   Reply With Quote
Old 05-16-2016, 11:13 AM   #9
elrand's Avatar
GFCI's work by watching for an imbalance between the hot and neutral legs not for current on the ground
