Just a note of caution...There have been multiple posts here about electricians unfamiliar with RVs wiring these things wrong and pumping 220 volts into your rig. If you do have a new outlet installed, be sure the electrician understands what you want.
That will be number 1 on the check list!
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
Don't know how hard it is to get to main service panel but from the looks of things
I would start over .goto. Home Depot get some 8/3 wire a 30 amp RV box some number
8 bonding wire a new 30 amp breaker wire staples
Only need #10cu wire. What are you gonna do with 4 wires on a 3 wire receptacle?
