Old 06-29-2015, 12:00 PM   #1
50 amp install at home
Need to install a 50 A plug at home. Likely need to run underground.
Any advice, etc.
Mike.............
Orange Beach Al
Mike & Sharon 2011 Cedar Creek 30RL
Dodge 3500 Mega Cab
MBeech is offline   Reply With Quote
Old 06-29-2015, 12:13 PM   #2
TURBS's Avatar
Do it right the first time and do not wire it for 220v!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 06-29-2015, 12:25 PM   #3
OntarioFireFighter's Avatar
Just installed a 30A outlet here last week... Thankfully, my panel's in my garage, so was an easy job. Plus, I'm an electrician, so that helped...
Short answer is - if you have to ask how to do it, probably should hire the job out...
Without knowing a lot more (distance, panel size and ampacity, physical layout and route) - can't really offer much advice.
If it's any kind of distance, I'd run a 15 or 20A circuit alongside the 50A, and mount it on the post or wherever you're thinking of putting the 50... it'll come in handy as a convenience outlet for tools, battery charger, vacuum, etc.
Use the proper cable, and account for voltage drop, at a minimum, you'll need #8, and if it's any distance, don't be surprised if you have to go to #6 or #4...
I don't know the codes or enforcement where you are, so don't know if an inspection and permit are required or not - but a qualified local sparky will.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 06-29-2015, 12:37 PM   #4
67cudafb's Avatar
TURBS
2011 32bhok Sabre
50 amp plugs are wired for 220V. 120V on each leg = 220 across the 2 legs.
1967 Barracuda fastback
2015 Wildcat MK 333
2010 Ram 2500 Mega-cab
67cudafb is offline   Reply With Quote
Old 06-29-2015, 12:40 PM   #5
TURBS's Avatar
I agree, seen 50 amp "thought I seen" 30 amp.
TURBS
2011 32bhok Sabre
Old 06-29-2015, 12:55 PM   #6
67cudafb's Avatar
Happens to me all the time
2015 Wildcat MK 333
Old 06-29-2015, 12:55 PM   #7
TURBS's Avatar
TURBS
2011 32bhok Sabre
Old 06-29-2015, 12:59 PM   #8
You would need to find out if your panel and feed to the house can handle another 100A load (50 A per leg). This really is a job for a professional.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-29-2015, 01:12 PM   #9
Not to get nit-picky; but it's a 50A load at 120/240 - not 100A...
I agree fully with bringing in a local, licensed pro!
Old 06-29-2015, 01:20 PM   #10
Mr. Dan's Avatar
Oh, no......... here we go again!
I wouldn't be surprised if this discussion bled over into what percent nitrogen exists in normal air.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
50 amp
