06-03-2013, 11:59 AM
#21
To the guy with the 30 amp with the dog bone. How is it working? I have one and will be using it at the lake in one week.
Frank
06-03-2013, 12:29 PM
#22
When we go out west to Alberta, we will stay in St. Albert Kinsman campground. They only have 50 amp hook up. When some body comes in with just 30 amp, the manager will lend them a 30 to 50 amp adapter that plugs into the end of the 30 amp cord. No problems at all. I have a 30 amp outlet on the side of my house. I plug into the 50 amp inlet on the trailer with a 25 ft cord that goes from 50 to 30 amps. No problems. It's not rocket science.
06-03-2013, 12:56 PM
#23
No, not rocket science, but having read some good advice about what you can run and what you can't if you're used to a 50-amp rig that has to "make-do" with 30-amps is helpful.
06-03-2013, 01:10 PM
#25
Originally Posted by another_newfie
i WANT ONE OF THOSE !!!
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
06-03-2013, 01:14 PM
#26
Frank
Mine worked fine at a local State Park...just remember you have 30 amps to work with..and ...if you dont have a 2nd a/c to run..should be ok
06-03-2013, 01:15 PM
#27
dretired, I ordered mine from Amazon. Arrived a few days.
06-03-2013, 01:34 PM
#28
A little food for thought. This is not 30A vs 50A, but actually 30A vs 100A. 50A service is the same as 240V household service....hot-neutral-hot-ground....there are two 50A 120V phases. For the adaptor to work, that single 30A hot has to be split between the two 50A phases so that every circuit in the camper is powered.
Bob
Bob & Doris
Roanoke, VA
2009 Toyota Tundra CrewMax 4x4 - 5.7L - 6 Speed Auto - 4.30:1
2013 Rockwood HW296
07-28-2013, 02:55 PM
#29
After posting that I would probally never use the 50 to 30 converter cord, I have now used it three times. Twice I was in a 50AMP only site, and once in a 30/50AMP site, but my power cord was too short, so I used it as an extension cord to get the extra two feet I needed to reach to power box.
It has turnd out to be a good purchase.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
08-07-2013, 10:48 AM
#30
Here's the risk of a 50 amp breaker and a 30 amp "weak link", i've mentioned before.
Photo courtesty IRV2.
