Old 12-20-2014, 07:41 PM   #21
electrical 50 to 30 amp
When you utilize a 50 amp service for 30 amp RV you need to understand the supply breaker is 'not' protecting you. Note the 50 amp service has 2 X 50 amp breakers, that is 100 amps of power. A 30 amp service has 'one' 30 amp breaker. When you plug a 30 amp RV supply line into a 50 source you have a 50 amp breaker in front of a 30 amp service. So, that means 'no' protection for the 30 amp RV, at least at the source.
captainchuck is offline   Reply With Quote
Old 12-20-2014, 07:51 PM   #22
davel1971's Avatar
true, but assuming the interior breaker is working as should you still cant draw excessive amps through the supply cable into the RV
David & Lynn
Old 12-20-2014, 08:06 PM   #23
Herk7769's Avatar
Originally Posted by youroo View Post
Not all! Youroo!!
Many campgrounds are rewiring and only installing 50 amp sockets. Youroo is correct and you should ALWAYS carry a 50 amp to 30 amp pigtail (dogbone) just in case you only get 2 50 amp sockets or the 30 amp socket is bad.
HAM CALLSIGN - KC3FFW
50 amp, service
