Old 08-06-2014, 09:09 PM   #1
BamaGrad's Avatar
50 or 30 Amp Portable EMS
My new Class C has only 30A service. I was planning to use 50A-30A dog bone. After reading the horror stories, I decided I need a portable EMS. So the question is this, should I buy a 50A EMS then use the 50A-30A Dog bone? or do I buy a 30A EMS and add it after the dog bone (if 30A service is spotty)?
BamaGrad is offline   Reply With Quote
Old 08-06-2014, 09:28 PM   #2
jtstromsburg's Avatar
If your rv is 30a, I would get a 30 ems.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 08-06-2014, 09:34 PM   #3
ironj's Avatar
if your trailer is only 30amp there is (really) no benefit to a 50amp surge, as a 50 amp coach uses 2 120v legs and your trailer only has one....so even if you plugged into a 50amp outlet with your 50-30 dogbone, your only getting the one leg.....
just buy the 30...its cheaper and it will do just fine...(tho you still may want to use the 5-30 dogbone)....sometimes those are a little less worn
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
