Old 09-30-2013, 05:31 PM   #1
50a surge protector vs auto leveling systems?
We have a 2011 Forest River Cedar Creek 36RE and kust got a portable TRC 34750 surge protector without LCD. Shortly after plugging in the surge protector our auto leveling system started beeping at us, showing "low voltage" and "error" messages. Does anyone have any thoughts as to why this might happen? Thanks SO much!
GRHooper is offline   Reply With Quote
Old 09-30-2013, 05:53 PM   #2
I would suggest that you take that back and get the Progressive Industries unit. It's Made In USA and has a lifetime warranty.
It sounds like your battery is low and that Guard has decided not to turn on the power to your RV. Do any of your 120v appliances work? Aren't there any status lights on the Guard?
Old 09-30-2013, 06:11 PM   #3
Thanks a lot, Barry.
Returning the surge protector is not an option, my battery is brand new, power continued to the RV, all the 120v appliances worked and there are no lights on the guard that give an indication of the problem.
Old 09-30-2013, 06:16 PM   #4
07 ThunderRoad's Avatar
It sounds like you have a low voltage - monitor issue. Check the voltage after the Progressive Industries unit. Is the voltage above 109 vac?
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 10-01-2013, 08:00 AM   #5
It might be that your converter (battery charger) is not working then. You'll need a volt meter to see what the battery voltage is when plugged in. It should be at least 13.2 volts (and normally higher).
Old 10-01-2013, 08:42 AM   #6
TURBS's Avatar
Leveler system is 12v not 120v.
Sounds like battery system has went wonky.
Buy a digital volt ohm meter for your camper your going to need it.
Doesn't matter if battery is new if the converter/charger isn't working it not charging.
Turbs
Old 10-01-2013, 10:11 AM   #7
Oakman's Avatar
Unplug from the surge protector and then plug your power cord directly into the power pedestal to see if the problem resolves itself. If it does then you probably have a defective surge protector.
Since your surge protector doesn’t have the LCD display I’m guessing you purchased a used surge protector or am I wrong?
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
leveling
