Originally Posted by LegacyFB38
Good question.
I know little about the EMS (this will be new to me in our new coach). Here is a section I copied from a manual:
"Midi-PCS automatically senses 0VAC between L1 and L2, and 120VAC between L1 and
Neutral, to determine 30A Service. The I/O Module has a current sensor which monitors total
RV current. When the current exceeds the 30-amp limit, the Midi-PCS will limit current by
shedding appliances that it controls. Once the RV current has dropped, the procedure will be
reversed and power will be restored to the shed appliance."
Interesting! It will not be trivial to wire up the circuits to be shed, and I think there is a limit as to the number of circuits available. Lastly, the EMS is not an actual circuit breaker...my gut is that it should not be used as a surrogate circuit breaker, but as an accessory to a RV currently wired with appropriate circuit breakers.
The type of system you are talking about is actually called Electrical Monitoring System, abbreaviated as EMS. As you said the Electrical Monitoring System monitors the load on your incoming power, if it finds that you are drawing too many amps it will shed appliances. This in my opinion is more a management arrangement because it is managing the load.
Progressive Industries builds a system they call an Elecrtical Management System and it is also known as EMS.
Most people on the forum talk about is this type of system. The PI EMS monitors the incoming power for several problems. Among these problems are over/under voltage, open ground detection, open neutral detection, reverse polarity, mis-wired pedestals, high/low AC line frequency, and surge protection. If it finds any of these problems it disconnects the power from your RV, thus saving your appliances from damage. It only protects the RV from these problems coming up to the EMS. If any of these problems is after the EMS, inside your RV, it does not detect them.
I'm not sure the Electrical Monitoring System monitors for all or some of the same problems. I have seen threads on the forum asking if it is possible to use both systems together.
IMHO, I believe the names should be switched.
