Old 07-18-2013, 09:19 PM   #11
Denver, CO
garbonz's Avatar
Originally Posted by herk7769 View Post
As I understand it, the high voltage pulse forces the deposited sulphates back into solution. Could be they work just as well as magnets on your fuel line, but so far so good.
Still smells like snake oil, but maybe. I have become skeptical, and have not seen credible research that backs this up that isn't produced by someone with a vested interest. Once the sulfate has formed and settled in the bottom of the casing, I think it is chemically impossible to bring it back into solution. But what do I know, I'm only a chemical engineer.
Hey, where are my copper bracelets? they keep me from having heart attacks, or is it arthritis? I forget. Oh yeah, its good for alzeheimers...
2017 Fuse 23T
Old 07-18-2013, 09:39 PM   #12
Herk7769's Avatar
Charging the battery takes lead sulphates from the lead plates and forces it back into solution as ions. Using a higher potential should get stubborn deposits off the plates and back into the electrolyte, but you can't keep a 15 or 16 volt hot shot on very long or the electrolyte will overheat and boil.
Least that is how I understand it. I "was" a Chemist (Villanova University - 1972), minors in physics and math, but have been flying for a living since then.
ID:	35700   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 07-18-2013, 09:48 PM   #13
kopy kat's Avatar
[QUOTE="kopy kat;424991"]As an after note regarding the pulse factor and sulfates...while discussing the short life of my 6 volts with the Interstate Battery distribution center the manager commented that they store their batteries on racks with pulse systems in order to keep them from building up the sulfates.
kopy kat is offline   Reply With Quote
Old 07-18-2013, 11:00 PM   #14
Denver, CO
garbonz's Avatar
okey dokey. keeping them from sulfating and reversing it, may be different, but maybe not. BSChE; University of Michigan 1975, MPh Environmental and Industrial Health 1984.
Pulsate away, maybe it is the solution after all
2017 Fuse 23T
Old 07-19-2013, 06:23 AM   #15
Herk7769's Avatar
Like I said, have not "used" the degree for anything except getting into the Air Force (life sucked for pure science graduates in 1972).
The whole "stage" charge concept works on the way the battery construction affects the batteries ability to take a charge (remove lead sulfate from the plate by forcing it back into the electrolyte based on the amount remaining and how deep in the lead the sulfate ion is buried). No generalization is accurate, including this one, but it works for me to understand how charge staging works.
A deeply discharged battery has the lead converted to lead sulfate fairly deeply and it makes sense (to me anyway) that more force (volts) would be needed blast that large sulfate ion off the lead and back in solution. That much voltage would hurt the battery (I would think), if it was applied for any appreciable amount of time, so the unit pulses (with a long off pulse to allow the electrolyte to equalize and cool between hits).
Old 07-19-2013, 11:36 AM   #16
kopy kat's Avatar
Correct (as far as I know- which isn't far at all)--that's why the extra thick plates on the 6 volt discharge over a longer period of time- and conversely also take longer to come up to a full 13.2 volt charge level...are we having fun yet?!
