02-21-2018, 09:33 AM
6 Volt Battery Box?
I am in the process of going from 1 12 volt batt to 2 GC2 6volt batts. I have searched hi and low online for a box to fit my new batteries. My new batteries (i bought from Sams Club) each measure 10.5" wide X 14.6" long X 11.5" high. I'm starting to think I bought the wrong batteries. Any suggestions? I have searched: this site, Amazon, etrailer, and NOCO. What are y'all using? I am open to 1 or 2 boxes.
Thanks.
Don & Kim
Willow Spring, NC
2012 Rockwood Ultra Lite 2604
2013 F-150 4x4 EB
02-21-2018, 10:02 AM
Thanks.
I built my own from plywood, painted inside with chemical resistant paint Home Depot. Drilled holes with hole saws for cables and ventilation and secured to floor with screws. PS the floor of the box at the front is longer than the sides to enable placing screws in front on the outside and also to move box around with batteries inside.
Also drilled hole in bottom for air to get in and placed batteries on 1/2 inch strips so as not to block the hole with the batteries. My are placed in my front storage compartment so the bottom hole goes directly to the outside. The upper vent hole hose is sump pump drain hose which I tied into the existing battery vent hose. It works for me!
Of all the things I've lost in my life the thing I miss the most is my mind!
02-21-2018, 10:21 AM
I got this at Batteries+Bulbs. Not cheap, but we'll made.
Two things:
-the lid is very secure
-the notches for the wires to pass through actually work.
02-21-2018, 11:47 AM
This battery box is the one I have. Very rugged, excellent quality.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
02-21-2018, 12:34 PM
Wal-Mart sells 6v boxes.
02-21-2018, 12:52 PM
Paul and Angela
Raleigh, NC
2018 Windjammer 3008w
02-21-2018, 01:24 PM
Those measurements are NOT for a single GC2 which should be 10.25x7.125 x 10.875" (LWH) or close to that... Could you have given us measurements for the pair instead of one?
Dual Box https://www.batterymart.com/p-hm426-...saAr-bEALw_wcB
________
Cam
2015 Georgetown 280DS
02-21-2018, 02:06 PM
I bought four 6v boxes from Walmart. Each one fits one battery. I also toyed around with using some Rubbermaid bins since mine are located in the front bay vs outdoors. Found some that were pretty close but went with the individual route. Good luck.
2019 Ram 3500 DRW HO Cummins, Aisin Trans and 4.10 gears.
2017 Flagstaff 8529 IKBS Classic Platinum Edition
02-21-2018, 02:41 PM
Originally Posted by Seadog1272
X2... have had it several years. I secure the lid with a luggage strap from Walmart
02-21-2018, 05:56 PM
I have the Torklift Power Armor box. It is ventilated with a locking cover. I have (2) Trojan T-105s on one side and my charge controller, battery monitor, inverter, and buss bars on the other side. https://www.torklift.com/rv/powerarmor
2015 Solaire 201SS
2015 GMC 2500HD Duramax
02-21-2018, 06:16 PM
NOCO Battery Boxes
Get NOCO 6v Battery boxes. Turn the so the handles are on opposite ends and they will probably fit in the same space as 24 size 12 volt batteries. There website has exact meaasurements.
02-21-2018, 08:04 PM
I just used regular group 27 boxes with straps. Be sure you make your cables long enough to allow the lids to fit onto the top. Don't forget to incorporate venting into the battery area to prevent hydrogen buildup. Use proper gauge battery cable, (6 gauge I think). You'll love how long you can go on the golf carts.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
02-21-2018, 09:03 PM
Thanks.
That does not sound like the dimensions of any GC2 I have seen. Boxes for GC2 batteries are the same footprint as the box for a Group 24 12v only taller and are readily available all over?
02-21-2018, 09:04 PM
Ditto. IF they are actually GC2 batteries
02-22-2018, 07:09 AM
opps, I'm an idiot.
Thanks for all the replys. As Cam and others have figured out, my measurements were for the 2 batteries, not each. I had drawn a box with the measurements on a sticky note that I had labeled "batt size" later when I went surfing for a box, I assumed I had measured just the 1 battery and not both. I have ordered the NOCO box that many of you are using. Thanks again for the help.
Don.
Don & Kim
Willow Spring, NC
2013 F-150 4x4 EB
02-22-2018, 08:12 PM
Don.
Good choice, pricier than others, but very sturdy/well built and worth the extra dollars.
