Old 11-29-2015, 12:00 PM   #11
Hi I have a 2010 CC 5th which i changed over to 2- 6v golf cart batteries and it made all the difference. I got a battery box made for 2- 6v end to end..... worked perfect for my location in the CC 5th . vented the new box by cutting out the vent connection on the old 12v box and screwing it to the top of the new box . No need for the y connection for the vent hose. this is a great mod and wish I had done it earlier
Bear
2010 34RLSA
06 Chevy Duromax/Allison
blynds is offline   Reply With Quote
Old 11-29-2015, 12:02 PM   #12
Witch Doctor's Avatar
Bear
That's interesting:
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 11-30-2015, 04:22 PM   #13
Placement is not of any concern for the batteries, as for venting "VERY IMPORTANT" with the gasses coming out of the batteries all the time while charging, and all the electric wiring and relays and controls that run all over RV's there is to many issues with (explosions) which is why they are vented!
If you are going to move the batteries to a different location also be aware of the length of cable as you might need to upgrade the cables, there is a good amount of power going through the cables, so you need to remember that also.
Hope this helps Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 11-30-2015, 07:30 PM   #14
Blackhat6mike's Avatar
Batteries.
If venting your batteries is a potential problem, you might want to give AMG batteries a thought. I have 5 AMG batteries and don't have to worry about venting them. Gives me a warm and fuzzy feeling to know I'm not corroding away my frame or going to blow it up when I turn my inverter on. Just a thought. They ARE more expensive.
I stuck with the 12vdc bats as a personal preference over the 6vdc units.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 11-30-2015, 07:36 PM   #15
Kenny kustom's Avatar
Absorbed glass mat.
AGM
2017 Dynamax Isata 4
Old 12-03-2015, 09:35 PM   #16
AGM batteries still require venting in case of an overcharge condition. They vent at 2-3 psi. In other words they do not need venting EXCEPT when you really need venting because something has gone wrong. Hydrogen gas is easy to vent, mixes readily with air so you don't heed a big vent but you need one. Overcharged conditions are usually accompanied with heat and an electrical problem which is probably when you don't want a confined explosive gas.
Brentf is offline   Reply With Quote
battery, rockwood
