Old 05-31-2014, 03:26 PM   #1
Chris1304's Avatar
7 pin issue
Have an issue when I plug my trailer into tow vehicle my right brake light stays on and no other lights work.. I've tested the trailer and everything checks out ok . So I have moved on to tow vehicle . Started testing pins and I have power to top 4 pins for some unknown reason ? Any thoughts
Chris1304 is offline   Reply With Quote
Old 05-31-2014, 03:32 PM   #2
Crusadernoob's Avatar
Possible internal corrosion in plug? How old is it, got a boat you put in the water a lot?
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 05-31-2014, 03:37 PM   #3
Chris1304's Avatar
Year old and have pulled plug apart and no corrosion noted.. Showing 13.6 volts on top 4 pins when only one should have power without brake pressed or blinker on.
Old 05-31-2014, 03:44 PM   #4
Phat Phrog Stunt Crew
awwall's Avatar
I am sure you have a diagram, if not here is one.
Sounds like something is shorted somewhere. Either in the plug or back towards the engine bay.
Name:	Wiring Diagrams_Page_1.jpg
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 05-31-2014, 03:48 PM   #5
Chris1304's Avatar
I'm getting ready to trace all wires back
Old 05-31-2014, 03:49 PM   #6
Chris1304's Avatar
Thanks for the diagram !
Old 05-31-2014, 05:33 PM   #7
Chris1304's Avatar
Ended up just cutting out the whole controller and ordered a new one.
Old 06-01-2014, 09:51 AM   #8
Explorer
Not sure if you found your problem but I had some issues similar and it ended up being a controller under the dash.
This is my post:
solved, wierd trailer light issue
Good luck
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 06-01-2014, 11:46 AM   #9
Chris1304's Avatar
New controller on order from Curt. When I pulled the old one out it was warped from heat and cracked so I'm assuming this should correct the issue I'm having. Thanks for all the help.
