Originally Posted by dea49
Mine is grounded to the inside of the tongue right where is comes out of the insulating sheathing.
I'm guessing that's the ground from the umbilical cord (i.e., it provides a wire from the frame back to the 7-pin's ground). However, lots of other stuff is then grounded to the frame. For example, look around your wheels and you'll probably see that the brakes have a positive wire going into them, and a ground wire coming out that is then attached to the frame near the wheels. The frame then provides the current path for the brakes from this point back to the one from the umbilical cord.
2011 Traverse LT, 3.6L, FWD
