Old 03-12-2015, 08:37 PM   #1
a/c 15k unit works as fan only
our SB 31rk has 2 a/c's, the living room is the 15k unit. it worked great when we first got it in summertime, and did not need it during colder months.
now as the temps are going up, we turned our a/c units back on, and the living room unit is putting out air as if we have the fan on. therm is set to auto and the temp set to x degree, and it comes on when the temp setting is reached but instead of cold air, it outputs regular air as if we have the fan on.
we set therm from auto to hi/lo for fan and that worked, then reset back to auto and only regular air comes out.
any ideas? thank you.
bill & jodi
stormy2000 is offline   Reply With Quote
Old 03-12-2015, 08:44 PM   #2
B and B's Avatar
Hello Stormy. I would say there is a problem with the compressor control or possibly the charge in the Freon is low. This would mean a tech needs to check it out.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 03-12-2015, 09:15 PM   #3
darn was hoping it was a switch or something. ok will call service and see what they can do as unit is still in warranty. thank you.
Old 03-12-2015, 10:06 PM   #4
BooBoo23's Avatar
I had that problem with my TT when I got it new. The answer was there was no refrigerant charge in it and the unit was sealed and could not be recharged, so it was replaced under warranty. The dealer was good about it and told me to not come in until he checked to see if he had a replacement, he didn't want us to leave it there. He called back in a couple hours and had one so we made the appointment and when I got there he had 3 people on it and I was out of there in less than 2 hours.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 03-13-2015, 08:32 PM   #5
mike.t's Avatar
Stormy.Call the service dept. before ya drag it down there. I have found most new RV problems are easy fix'es.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 03-14-2015, 12:09 AM   #6
ok i will call prior to, as our dealer is 2 hr drive away, though there is a CW real close by, and does warranty work for FR.
thanks again
bill & jodi
fan
