Old 04-12-2016, 11:47 AM   #1
A few 110 Volt outlets not working
Hi
I have a 6 year old Palimino 253. The 110 volt outlets do not wok in the bedroom , the slide and where the refrigerator plugs in.
I suspect these may be in series. Breakers work and have power to them. Is there a junction box someplace on the trailer I should check for corrosion a broken wire. Also how do the outlet boxes come apart , looks like little tangs holding them together.
Thanks very much
paul
Paul 93 is offline   Reply With Quote
Old 04-12-2016, 12:09 PM   #2
TURBS's Avatar
Check your gfci in the bathroom
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-12-2016, 01:30 PM   #3
Thanks , I did that ...... that circuit works fine
Thanks for the suggestion
Old 04-12-2016, 01:37 PM   #4
Time for the volt meter. Start at the first outlet closest to the breaker box. Very likely a loose wire at the push on connector. These cheesy outlets use a push on rather than a screw terminal for the wires. They are infamous for coming apart. New outlets are cheap at any hardware store.
donniedu is offline   Reply With Quote
Old 04-12-2016, 01:59 PM   #5
the connectors are cheesy, I have checked all the boxes that are not working ...only the one under the fridge cover has two wires going to I assume another box all the other boxes only have a single wire in no wire out ...so I am hoping that somewhere there is a junction box ..... I cant find the box.
Old 04-12-2016, 02:37 PM   #6
hammer55's Avatar
do you have a basement recep anywhere or in a cabinet, just a thought
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 04-12-2016, 03:01 PM   #7
I cant find anything, been everywhere but on the roof .... unscrewed every access panel I could find.
Still appreciate all of the advice.....
Old 04-12-2016, 03:19 PM   #8
Have you actually checked voltage across each breaker? Without a volt meter your really shooting in the dark.
Old 04-12-2016, 05:13 PM   #9
Good point , I used a test light not a volt meter .... I will check actual voltage
paul
Old 04-13-2016, 06:18 AM   #10
Voltage at the breakers is good......
Old 04-13-2016, 07:28 AM   #11
hammer55's Avatar
did you check voltage to ground, sometimes you lose a neutral, check neutral connections at the panel box, is there a junction bow where the main trailer cord comes in, they might have a splice in there, checked all external plugs for loose wires, just shooting in the dark
Mark & Annie
Old 04-16-2016, 07:44 AM   #12
What little hair I had left is now gone. Thanks for all the help .... if I cant find it I will take it to the dealer.
paul
electrical
