Old 07-23-2016, 09:32 AM   #1
AC Circuit Breaker Trips
When running the AC off the generator while driving, the circuit breaker on the AC trips. No problem when stationary, only while moving. Any thoughts?
biznsa is offline   Reply With Quote
Old 07-23-2016, 04:59 PM   #2
Head Rambler
Can you post the model of the RV, the Generator, and the Air Conditioner?
It will help in diagnosing the problem.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 07-23-2016, 07:37 PM   #3
2006 Sunseeker, Onan 4kw, Coleman 13.5K BTU.
Old 07-25-2016, 12:21 PM   #4
Head Rambler
Since you only have the problem when moving, have you checked the wiring in the panel, to the A/C and in the genny? I'd start by doing that. Since you didn't say that it happened on shore power, it's probably between the genny, the transfer switch, and the power panel.
Gotta go campin!
Old 07-25-2016, 12:58 PM   #5
WolfWhistle's Avatar
Are there any other "load" appliances on such as fridge or water heater? If yes, turn them off or switch them to LPG.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 07-25-2016, 01:03 PM   #6
Probably vibration. Breakers use electromagnetic force to trip the switch. If the breaker is weak, adding vibration to the electromagnetic force could exceed the force required to trip it.
Can you switch it with another breaker and see if it still trips?
johntaylor is offline   Reply With Quote
Old 07-25-2016, 03:13 PM   #7
When you change power source from shore to generator (or generator to shore), are you turning off the A/C before you change sources, and leaving it off for a few minutes after changing?
I used to just start the generator and then disconnect shore power leaving the A/C on the whole time. I was throwing breakers all day long. After I started turning off A/C before transitioning power sources I haven't had a single instance.
Carl
ckabrahamson is offline   Reply With Quote
Old 07-26-2016, 11:07 AM   #8
Back On The Go
I just completed a 4300 mile trip in my 2016 Georgetown 270S, with Cummins Onan RV QG 5500 genset and had the same problem once I got south with hot weather. A common denominator is rough, very bumpy roads - one (of 2) of my generator (not the ones in the rv itself) circuit breakers tripped 3 different times. Cummins Onan support tells me that there is probably a loose connection somewhere so I'll look around and if I can't find anything that appears to be loose, I must (heaven forbid) take it back to the dealer to check and (hopefully) tighten anything and everything.
2013 Ford C-Max Hybrid
2 Janis Hybrid Bicycles
Not too serious about anything except what affects health and happiness.
salwolfe is offline   Reply With Quote
breaker
