Old 06-20-2014, 07:02 AM   #1
BeeGee's Avatar
AC with a generator
I have a 20 amp generator. Will this run the ac ? Will it damage anything to try?
2012 Ford Lariat F-350 Super Duty
2014 Forest River Cherokee Wolf Pack 27 TH
BeeGee is offline   Reply With Quote
Old 06-20-2014, 07:11 AM   #2
SKnight's Avatar
A 13.5k AC unit is on the far jagged edge of what a 2,000 can handle. I've seen it do it but barely and we didn't check the voltage so I don't know where that stood.
Old 06-20-2014, 07:23 AM   #3
mark0224's Avatar
Don't do it with a 2000 watt when the ac has run once and is hot it won't kick back on, a 3500 watt minimum to run ac. The 2000 watt will trip the reset on the Generator when it tries to come back on.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-20-2014, 07:39 AM   #4
TURBS's Avatar
As stated a 2000 watt is pushing it.
I wouldn't recommend it.
A 13.5k a/c draws about 16-20 amps during start up then runs about 12-14 amps while running.
Your converter is always running and it sees about 3-5 amps continuously.
A 3500 watt continous watt gennie would in my opinion be your minimum.
Generators can sometimes be misleading.
I seen one listed at "2000" watts but in small print it said "surge" watts.
Running watts was around 1650.
You need to look at running watts.
Old 06-20-2014, 07:41 AM   #5
TURBS's Avatar
Low voltage would be a BIG concern!
Old 06-20-2014, 07:50 AM   #6
Blackrock's Avatar
What is the KW rating of your 20a generator?
It takes a good 3500KW to run most of the A/C units.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 06-20-2014, 07:54 AM   #7
Arefbee's Avatar
Just to be clear - is it a 2000 watt generator or (20Amp x 120volt) = 2400 watts.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 06-20-2014, 08:21 AM   #8
jonrjen's Avatar
Don't do it, not enough output to keep things in check. This is why most people who have a 2K generator have two 2K generators and a parallel cord to tie them together making the total output at 4K.
As for why many of these folks to two 2K generators is that if a/c is not needed one generator may meet their needs for dry camping. Or that two 2K generators is much lighter to move around than the weight of a 4K generator
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 06-20-2014, 08:26 AM   #9
TURBS's Avatar
Actually. ......
Old 06-20-2014, 11:51 AM   #10
We have the Yamaha 2300 HSIC and it easily runs our A/C. I did install a hard start kit to help with the initial start up.
climbbike is offline   Reply With Quote
generator
