Old 02-24-2015, 06:38 PM   #21
2014 XLR 27HFS
dave961's Avatar
I unplugged from the house, started up the generator, and watched the PI display as I tried to turn on the AC. The lowest it got was 117. I turned off the genie bypassed the PI surge suppressor and had the same results. Looking more carefully as the thermostat screen flickers, I believe the code is E1 - then the E goes away and something else flashes, then it comes back.
I'm really concerned now because not even the fan will come on when I'm plugged into the house power - and I have a trip planned this weekend. I've never had issues before and don't understand why just trying to run the AC from the genie would cause this.
J Free - I took the cover off, but do not see any fuses inside the generator. I attached a pic. Hoping the sketchy manual I got talks about this.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 02-24-2015, 07:55 PM   #22
Check your breakers on the generator you should have two shut them off and start gen 1st then put them back on and try a/c....
gtony2
gtony2 is offline   Reply With Quote
Old 02-24-2015, 07:56 PM   #23
TURBS's Avatar
gtony2
It's doing the same thing on shore power.
TURBS
generator
