Old 02-29-2016, 12:09 PM   #1
Adding 120 volt outlet to Slide Out
Hello all, I have a 2012 V-lite and I have removed the dinette set and replace it if a cabinet I built. Now I would like to have 120 volts in the slide out to power up some electronics that going in this area. There is no 120 volts power to the slide from the factory. I'm just trying to get ideas of how to run power to this location. Just wanted see if anybody else has ever done anything like this and if so how. So let me hear your ideas. Also just FYI this trailer came with 30 Amps service but it has be replaced with 50 amp.
getastro is offline   Reply With Quote
Old 02-29-2016, 07:14 PM   #2
Use coiled cable, conduit and / or wire moulding.
mfMcFroggierPod is offline   Reply With Quote
Old 02-29-2016, 07:36 PM   #3
Some folks just add the outlets which are wire to an outside female receptacle and use an extension cord plugged into a 20A receptacle that most parks have along with a 30/50A receptacle.
slide, slide out, electrical
