Old 06-07-2012, 07:52 AM   #1
DAISY BOYKIN's Avatar
Adding start/run Capacitor
Has anyone added a start/run capacitor to a 15,000 BTU Coleman Mach A/C to assist in starting with a generator? I have a 2011 Rockwood 8285WS with a 15,000 BTU A/C. When I opened the capacitor compartment, I found a (small) 7.5 uf cap that goes to the fan motor. I also found a larger cap of 40 uf that goes to the compressor with several wires. I have purchased a SUPCO "E" class SPP6E 90-277V 88-106 uf cap to assist the A/C starting when the generator is being used.
As indicated with the spec sheet displayed, do I just piggyback with the compressor cap as indicated with the CSIR unit. As you can see from the spec sheet, It displays PSC unit and CSIR units. Which do I have?
Any info will be greatly received. My Boliy generator has the "SMART" throttle. I am trying to get all the help I can to use the "SMART' throttle.
I have read and reread the "MOD" for the start cap on the web. I am still confused as it shows the smaller of the two caps being replaced which on my A/C is used for the fan motor.
Name:	CAP SPECS.jpg
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
DAISY BOYKIN is offline   Reply With Quote
