Old 11-19-2013, 08:44 PM   #1
Additional Battery
I was wondering if anyone has taken a single battery configuration and added a dual battery configuration on their unit? Is it worth the time, money and effort to do so?
ndose50 is offline   Reply With Quote
Old 11-20-2013, 12:03 AM   #2
bikendan's Avatar
it would help if you at least posted what type of RV you have.
some RV's won't have the room.
that said, having two or more batteries is only worth it if you dry camp or boondock.
if you only camp with hookups, there's no need to add a battery.
we almost always dry camp so having two batteries is a must for us, along with our Honda 2000.
Old 11-20-2013, 12:30 AM   #3
KMP44's Avatar
It is, generally, an easy process to add a second battery. You want matched batteries - same type, same age. If you have one new one already, you can add a second one for around $100-200 depending on what brand and size you use. For a trailer with an exisitng tray on the tongue big enough to hold 2 batteries, then all you need is a plastic battery box ($10) and couple short wires to connect them. Most dealers will make the wires up for you, or you can do it yourself. There are some good reference drawings on this forum and and on some other sites for details on this. Not hard to do, but you need to use the right size wires and connect them correctly.
As Dan mentioned - this is a great thing to do if you camp without electric hookups. You essentially double your battery life.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
KMP44 is offline   Reply With Quote
Old 11-20-2013, 05:49 AM   #4
sail2liv's Avatar
How much help does tow vehicle battery give the battery in the trailer when it is connected? Some TV have place for second battery under hood....if that will help support the one in the trailer.....but TV would have to be connected....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 11-20-2013, 06:43 AM   #5
Sorry Bikendan, I have a 2014 Coachmen Freedom Express 292BHDS. I have been having issues with getting my info to stay with my name. There is plenty of room for an additional battery and box if I want to add. We usually camp with hook ups if it is for an extended stay. For weekend camping we usually dry camp. Most of the time we are good with one battery but I always like to be prepared. Thus, lookig to add that additional insuarance. I have seen that they have switches that allows you to select between 1,2 or off for the batteries. I really like that option due to really giving me flexibility in the system.
Old 11-20-2013, 06:48 AM   #6
Herk7769's Avatar
Not as much as you would think. The construction of truck starting batteries is significantly different than a deep storage battery.
The truck battery has thin waffled surface plates to give up electrons easily in order to provide a LOT of power for a few minutes of starting; then recharge quickly. They are rated in Cold Cranking Amps (CCA).
Dual Purpose (Marine) batteries are usually installed as OEM and are a compromise between cost and performance as a house battery. They normally have their rating in CCA but also have an RC rating on it somewhere. This stands for Reserve Capacity in Minutes at a 25 amp load and is calculated differently than the Amp Hours of a Deep Storage battery which is the hours a battery can deliver a 20 amp load. To convert RC to AH for comparison, multiply RC by 0.4167 and the result is AH. So a 200 RC battery has the same battery capacity as a 83 AH storage battery.
The Deep Discharge (House) storage battery has thick solid plates with minimal surface waffling in order to pack as many electrons into the same battery volume as possible and release them at a low rate for a long time. They are rated in Amp Hours.
Since it is easier to give up electrons from the starting battery without the truck running, the trailer battery will be constantly trying to charge the truck battery.
Read the attached PDF and graph on the Peukert Effect. It shows how a storage battery's ability to deliver electrons at a given rate is reduced as that demand increases. If you ever plan on using an inverter, the high demand requires multiple batteries in order to keep the load on any one battery from exceeding the optimum discharge rate.
See the attached PDFs for more information and there is a great FAQ in that area of the forum.
Name:	battery voltage and capacity Curve vs Discharge Rate.jpg
File Type: pdf Automobile Alternators as Chargers.pdf (805.9 KB, 28 views)
File Type: pdf How to correctly interconnect multiple batteries to form one larger bank.pdf (106.1 KB, 48 views)
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 11-20-2013, 12:31 PM   #7
bikendan's Avatar
well, then you need to get a Blue Seas marine battery switch and a second matching battery. the Blue Seas has the 1 or 2 battery selection.
i waited until the cheap OEM one from the dealer expired and bought two brand new matching batteries. didn't have to do any mods other than bolting two battery boxes to the tongue and adding the disconnect switch.
we can easily go 4-5 days without having to recharge the batteries.
Old 11-20-2013, 12:41 PM   #8
If you're just going to switch between the two batteries, no need for them to be matched.
Old 11-20-2013, 01:12 PM   #9
TURBS's Avatar
I agree.
The only reason they'd need to be Matched is if they were ran or hooked together.
Turbs
Old 11-20-2013, 01:42 PM   #10
chiefly1's Avatar
A second battery is a great addition if you dry camp. You do not need matching batteries if you use a switch and it gives you side benefits in charging or isolating the batteries as needed. I run two banks with 4 batteries total and have had great success with this setup but we spend a week at a time dry camping. Years ago when I was running one battery and it died while dry camping taught me a lesson in having options. Adding a second battery is a good option and I suggest the switch is the way to go to avoid a battery going bad killing your good one...
chiefly1 is offline   Reply With Quote
Old 11-21-2013, 06:16 PM   #11
My trailer came with a single battery, and we definately wanted the 2nd battery as we mainly dry camp... There was no room for the second battery box on the frame, so I built my own box out of wood and turned them 90 degrees on the frame and they fit perfectly... 2 - 12 v 100AH gel cell batteries.. While doing that, I wired up an extension cord with a female end on it to the batteries.. On my solar panel, I have a male cord end off the charge regulator... All I need to do is throw in an extension cord in the truck and I can set the panel wherever on the site I need to...
Camped: 2024 (Days/Nights) - 4/3
2023 (D/N) - 34/27, 2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
glen1971 is offline   Reply With Quote
Old 11-21-2013, 07:25 PM   #12
EricInColorado's Avatar
herk,
I geeked out and read the articles you posted.
But I missed what I need: What gauge wire do I use to make jumpers for my batteries when I set them up in parallel? I just have the usual size rv deep cycle battery that came with my Roo.
Thx
Eric, Tara, and most of China
2013 Camping Nights: 2
2014 Camping nights: 31
TT 2014 Rockwood Roo 183
TV 2012 Nissan Armada
EricInColorado is offline   Reply With Quote
Old 11-21-2013, 08:21 PM   #13
Herk7769's Avatar
Originally Posted by EricInColorado View Post
herk,
Thx
Between the batteries; the bigger the better to keep the "internal" resistance as low as possible. (1 - 0 is good). The run to the inverter depends on the fuse size you install inline.
Here is a chart that will help you decide.
Wire Capacity Chart
battery
