Old 09-05-2012, 08:44 AM   #11
Swamp Camper
Ive had this camper for 5 years and maybe its labeled wrong. I never noticed it but ill check. Thanks for that suggestion Ill check it out. Im dealing with hurricane ISSAC damage to my hose now so lots to deal with. Thanks agin for your help. This forum helps alot.
2007 F250 diesel 6.0l
jasper is offline   Reply With Quote
Old 09-05-2012, 09:13 AM   #12
CypressNova's Avatar
IMO the AC shouldn't be on a GFCI circuit, but apparently your's is and has been working like that since 2005. A GFCI circuit, whether protected from a breaker or receptacle, trips when it sees between 5 to 7 milliamperes of current difference from the amount of current that went out from the circuit to the amount that came back from the load. GFCI's do malfunction, there are testers to prove that they will trip as designed. It doesn't take much to trip a GFCI, that's how they protect your from electrocution, moisture is your worst enemy. You have severL options, test the GFCI, replace the GFCI, remove the cover from the AC and look for an issue or move the AC to a none GFCI protected circuit. Since you said it trips after the AC has run for 10 minutes, which is probably when the AC starts making water, I would suspect worn insulation on a wire in the AC that is exposed to the AC condensate. Hope this helps, Good Luck.
CypressNova is offline   Reply With Quote
Old 09-06-2012, 06:08 AM   #13
Swamp Camper
GFCI Tripping/AC breaker tripping
Does anybody know if low freon in your AC will make your breaker trip.
Old 09-06-2012, 06:19 AM   #14
Herk7769's Avatar
It will not.
As stated previously, it trips when there is a VERY small current difference on the CURRENT coming in on the BLACK wire of the circuit and out on the WHITE (Neutral) wire. It uses the bare copper wire as a reference.
Is the GFCI you are talking about IN the camper, or the one on the pedestal?
HAM CALLSIGN - KC3FFW
Old 09-06-2012, 06:28 AM   #15
Swamp Camper
Its in the camper. Could be a moisture problem due to a lot...a whole lot of rain in Louisiana lately. Ill have to look for wires on top of the camper (AC).
Old 09-06-2012, 06:38 AM   #16
Herk7769's Avatar
My guess is you have a current leak up in the Air Conditioner at the compressor.
Since all Neutral wires are connected, maybe the current leak at the AC is drawing down the neutral at the GFCI outlet enough to trip it.
air conditioner, breaker
