Old 04-01-2015, 01:07 PM   #1
All lights good except running lights - why?
I'm hoping you folks can help me out here. My 2011 Rockwook Roo's turn signal and brake lights work, but the running lights and tail lights don't. I'm pretty sure my tow vehicle's wiring is correct and the problem is on the trailer side due to the fact that my diagnostic LED tool says it's correct, and when I hook up my vehicle to another trailer the running lights do work. I cleaned the connector to no avail. I tried to find a wiring diagram - no luck. Has anyone had a similar problem that can point me in the right direction? For example, does the running light circuit have a separate return to ground than the brake lights that may have become disconnected?
burtlamborn is offline   Reply With Quote
Old 04-01-2015, 01:26 PM   #2
Left Coast
Has to be broken/pinched wire as they use the same circuit. Have access to meter/test light? If trailer battery is charged, you can use a fuse-stat (automatic re-setting fuse), jumper trailer pig-tail plug, for power, so you can keep tv out of way. The running light ground depends on your siding material. Some lights use the attaching screws as the ground, and fiberglass needs a separate ground source. Finding the connections, where they are, is anybodys guess.
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
Old 04-01-2015, 01:33 PM   #3
TURBS's Avatar
There should be a wiring "junction" box just under the front of your camper.
Start there.
TURBS
08 duramax tuned n modded, 32bhok Sabre
TURBS is online now   Reply With Quote
Old 04-01-2015, 02:38 PM   #4
Linnemj's Avatar
We went round and round with this on our XLR last year. I had a electrician look at it - no luck. It took two trips to a very competent independant RV tech to solve the issue. Ours turned out to be a pinched wire at one of the tail lights. It was run incorrectly at the factory and after 2 years of use it failed. Our fault was intemittent.
The place to start is your junction box where the 7 wire connects to the unit. I hope you are lucky and find it there!
Jim & Nicky
2012 Forest River XLR 29 MBV
2010 Dodge 2500 Cummings
Honda ST1100
BMW R1100R
Linnemj is offline   Reply With Quote
Old 04-01-2015, 02:57 PM   #5
Mowgli64's Avatar
Brake and turn signal lights use a different wire than lights. The lights are usually the brown wire at the plug so start there and work your way back.
2015 Wildwood X-Lite 271RBXL
2013 Ford F150 Crewcab Ecoboost
Mowgli64 is offline   Reply With Quote
Old 04-01-2015, 02:57 PM   #6
geotex1's Avatar
Step 1, feed +12VDC directly to pin 3 on the trailer connector. If holding it with square nub at 12 o'clock and terminals facing you, it's the pin at 1 o'clock. Put your house battery is in-place, then just bridge a 7.5A ATO fuse between pin 4 (11 o'clock) position and pin 3 - same way campers light the running lights while in the CG. If they work, you know your issue is on the TV side for certain, if not you are certain it's camper side. Step 2 is finding the break in continuity, and it would almost certainly be a break in the +12VDC with all lights out because lights are grounded locally in large part whether on aluminum siding or via screw/lug to chassis. Check trailer plug to junction box first as others said in hopes it's easy. If not report back for some advice in branch testing.
geotex1 is offline   Reply With Quote
Old 04-01-2015, 03:40 PM   #7
abjb's Avatar
Maybe start at the opposite end.
Step 1: Pop a running light lens off and check for corrosion (wiggle the bulb).
We had 4 not working last inspection. Contact cleaner and dielectric grease, now they all work all the time.
Although none of them working does sound like an open wire.
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 04-01-2015, 04:00 PM   #8
TURBS's Avatar
Originally Posted by Flybob View Post
You don't say what your TV is, but many trucks have separate fuses for trailer running lights and trailer brake/turn signals are also separate from the TV running lights. Look in you TV owners manual and check. My Trailer light fuses are in a totally separate fuse panel inside the truck.
He said he tried tv on another trailer and the lights worked on other trailer.
TURBS
Old 04-01-2015, 04:02 PM   #9
Flybob's Avatar
Yup missed that detail
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 04-01-2015, 04:05 PM   #10
Well wake up!
light
