Old 08-10-2011, 12:23 PM   #1
another battery question
I think I have a load on my carriage batteries. The wall indicator showed my batteries to be 1/3 or less charged. I took them out of the coach and charged them. After re-installing they last about a week, while on shore power, before they again were down to 1/3 charge.
When I start the engine, the wall indicator shows 100% charge. I know that is false as I can not run a slide after turning off the engine.
I have a 2007 Georgetown XL with an Onan 5500 Gold Marquis converter.
If I have to try to run down a load or short, how do I set up the meter? I'm a real rookie at this.
ncvet is offline   Reply With Quote
Old 08-10-2011, 12:42 PM   #2
KyDan's Avatar
If your batteries are running down while on shore power your converter is not
working.
Could be a bad converter or blown fuse or tripped breaker.
Hopefully some other Georgetown owner will suggest what you should
be looking for.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 08-10-2011, 01:24 PM   #3
When I plug the shore power in, I hear the same 'click' from the box that I have always heard. Not an indicator that the converter is working, eh?
Can I plug shore power in and measure with meter at batteries?
Old 08-10-2011, 01:34 PM   #4
TURBS's Avatar
that "click" you hear is the transfer switch.
not the converter .
sounds like a bad converter or fuse/breaker as previous poster mentioned.
Old 08-10-2011, 01:35 PM   #5
ken0042's Avatar
Yes. Measure it first to see how many votls it shows; then connect to shore power. I know on my system shore power reads as about 13.6 volts.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 08-10-2011, 01:48 PM   #6
Boyd's Avatar
I recently tossed a battery that plain old would not take a charge. It would read 100% while charging but the moment it was removed from the charger it would test at no more than 11.75 volts.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
battery
