Old 08-15-2016, 06:12 PM   #31
Witch Doctor's Avatar
Or if not hidden in the belly someplace
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-15-2016, 06:25 PM   #32
Originally Posted by Witch Doctor View Post
AS I stated earlier a WFCO will not ever go into bulk charge, and will not drop down to float at 13.1 even after not reading any loads for 48 hrs, per the manual.
Is that why WFCO have so many class action suits against them because they have been lying to us consumers for years and finally got caught.
WFCO Specs:
Bulk: 14.4 V
Abs: 13.6 V
Float: 13.2 v
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 08-17-2016, 08:51 PM   #33
MNtraveler's Avatar
I asked him if he checked the voltage at the battery.
He said it was 13.5v at the battery with the converter on and then disconnected the wires and had 11.6v.
How could the converter voltage not be getting back to the battery?
You can get good V readings on the cables but the power is not getting through (or not fully) if the battery wires are not solidly attached. In essence you are testing and jumping current from the wire from the converter to the wire that is attached to the frame/ground. In the future I would suggest testing at the cables AND just touching the battery terminals themselves to see if it's the same reading.
Two bad new batteries at once that are both seems like a crazy anomaly. Not accusing anyone of anything but two incorrectly installed batteries at once is way more likely and could have damaged the batteries too.
Interesting to see how this turns out.
Land of 10,000 Lakes
2016 Forester MBS 2401R
Nights camped 2016: 19; RV to date: 22
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 08-17-2016, 09:20 PM   #34
Yes. I made the mistake of installing the battery incorrectly years ago blowing the reverse polarity fuses. Since then, I always label the battery terminals red and white and with reminders as to which one gets hooked up and unhooked first. I agree that it seems impossible to have gotten two bad batteries in a row. I have ordered a new battery and will be installing it tomorrow. I will keep this thread updates for sure.
2010 Rockwood Roo 23RS
2015 F150 Lariat Supercrew 3.5l EcoBoost. Used to tow with 2006 F150 XLT Supercrew 5.4l V8. The EcoBoost is so much better!
DirtSquirt is offline   Reply With Quote
converter
