04-15-2015, 05:08 PM
Another EMS HW30C Install thread
Hello,
I know there are several threads about installing the EMS power manager but I had some specific questions about my set up. See the attached pictures for reference.
First, rather than disconnecting the incoming AC line from the power panel, can I just cut it and splice the EMS inline? Is there any reason not to do that?
I'm thinking that I might put the EMS in the "cable bay" which is right next to the power panel rather than behind the power panel. I would put a couple of strain reliefs on the cable of course - so I don't yank it out of the EMS when hooking up to the pedestal.
I'm also thinking I should add a battery disconnect on the DC side. As far as I can tell, there is not one anywhere. To disconnect DC power, I have to pull the cable off the battery. Again, can I just cut the red wire behind the panel and splice the disconnect switch in there and mount it to the wall by the panel?
What do you recommend for a disconnect switch?
I think I have a pretty good handle on this but i just wanted to run this by the experts to make sure I'm not overlooking something.
2015 268RKS Vibe Xtreme Lite
2012 F-150 EcoSCREW Max Tow
04-15-2015, 09:13 PM
Experts? He called us what!
Thats a good question, I hard wired mine by splicing the 10 gauge wire coming into trailer. Im sure another member will chime in and have probley already have done this but Im not sure with your set up having different power supply cord than mine.
http://www.forestriverforums.com/for...30c-78700.html
2006 Honda Goldwing
2012 Toyota Tundra DC s(sold)
2015 Cherokee Grey wolf 19RR Limited
2017 F150 Super Crew 3.5eb 5.5
04-15-2015, 09:43 PM
The instructions from PI suggest that you cut the existing power supply and fit each end into the EMS unit. Depending on where you wish to locate the unit you may not have enough cable length for this to be possible. If so connect the power center end to one side and buy a suitable length to run from the other side of the EMS to the power center.
As far as your 12V DC disconnect switch...most are located close to the battery before any other wiring.
Dave
04-15-2015, 11:02 PM
I bought a couple of feet of 10-2. I disconnected the incoming line at the panel, connected that to the line side on the EMS, connected one end of my new wire to the load side of the EMS, and connected the other end to the line side at the panel. That gave me plenty of slack to work with. If I want to take it out if ever selling my trailer, I just connect the original feed line back to the panel.
Sent from my phone using Tapatalk.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
04-16-2015, 07:21 AM
10-2?? Aren't you missing a wire? Black, White, Green?
Camped: 2024 (Days/Nights) - 4/3
2023 (D/N) - 34/27, 2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
04-16-2015, 08:54 AM
10-2 wire includes a ground wire. There are actually three wires inside. 10-3 wire would have three primary wires and a ground for a total of four wires.
04-16-2015, 08:58 AM
I pulled the in coming line going into distribution panel out and ran it to incoming side of ems then run the new wire from outgoing side of ems back to the distribution panel.
That way you can work on ems outside of cabinet.
Then when done put it behind distribution panel.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
04-16-2015, 08:00 PM
I was assuming he went with SOW or SJOW (stranded conductors).. If he used romex (house wire - solid conductors) then I get the 10-2... With SOW and SJOW 10-2 would not have included the ground wire...
04-16-2015, 09:18 PM
I used Romex, the same as used by FR.
04-18-2015, 12:19 PM
Okay, so I like the idea of pulling the power cable from the panel rather than cutting the cable but...
I can't get the cable out of the panel. In the picture, you can see there is a gray strain relief doohickey holding the cable into the back of the panel. There is what looks like a blade that has been pushed down to pinch the cable so it doesn't pull out. How do I release the blade?
I've tried pulling up on it but it doesn't seem to want to budge and I don't want to break it (much). It seems like for this to work, the blade won't want to back out but how do you release it when you want to?
04-18-2015, 12:27 PM
It's a one use connecter.
On the 3 ems units I've installed I've had to break all three to get it out.
TURBS
04-18-2015, 12:35 PM
Thanks. I was afraid of that... Frustrating.
04-18-2015, 05:19 PM
Fell back to plan A - cutting the cable. Pretty straightforward install - aside from the cramped location and balky cables.
Powered everything up and got the E0 code - w00t!
There's something I'm a little confused about however. Once it got through its boot sequence and started delivering power, the amp value never went above 0. I started turning on lights (DC) and the converter (fan) kicked in. As I turned on more and more lights, the voltage dropped from 120 down to 111 but the amps stayed at 0. Is that normal?
I didn't turn on any AC items but I would have thought that the converter would be pulling more than an amp - no?
04-18-2015, 05:49 PM
Did you run the power wire through the coil on the load side. I recall that's what senses amps load.
Dave
04-18-2015, 05:51 PM
Dave
Yep
TURBS
04-18-2015, 06:36 PM
That's my experience as well but they're cheap and readily available at any home/hardware store. Just be careful in removing it from the panel so as to not damage the hole in the panel.
04-18-2015, 06:38 PM
And make sure the arrow is pointing in the right direction. It's engraved in the side of the coil and hard to see, especially in low light conditions.
04-18-2015, 07:28 PM
Yeah, I ran the power wire through the sensor. I had the arrow toward the inside (the terminals). I'm not quite sure what the arrow means since it ends up pointing perpendicular to the current flow. Why have an arrow to indicate the side vs. a dot or something. Makes me think I'm missing something...
I guess I'll have a double check tomorrow. Ugh.
04-18-2015, 07:32 PM
I swear I could not find this thing either in the store or online. I know I've seen them before but I don't know what they are called so my google searches for conduit connector or outlet strain relief were not yielding anything useful.
Even if I had found one, I'm not sure how to destroy it gently and not break the panel hole. Anyway, I ended up leaving it in and cutting the cable.
04-18-2015, 07:36 PM
2 or 3 items down
http://www.electronicsurplus.com/hardware/strain-relief
TURBS
