Old 06-11-2014, 09:50 AM   #11
TURBS's Avatar
Originally Posted by kyjellywhite View Post
I would totally be ok with paying a $150 to get this how I want it, considering what I have invested in it. Time to try to find some gen guys in the yellow pages I guess.
Check with big electrical contractors whom specialize in generators "sales and service".
TURBS
"Sabre owners united"
Old 06-11-2014, 10:07 AM   #12
Kyjellywhite
kyjellywhite's Avatar
Originally Posted by Cypressloser View Post
To me this looks like a regular twist lock receptacle (page 8 in your manual), you should be able to find an adapter at RV dealerships or online.
Or am I missing something?
Obviously that manual is full of crap because these are my actual receptacles. The 25A is for 250v
kyjellywhite is offline   Reply With Quote
Old 06-11-2014, 10:16 AM   #13
TURBS's Avatar
But wait.
You have a 25 amp 120 v three Prong outlet .
In fact the adapter fordidaho pictured won't work.
Edit
You need a three Prong adapter for the 120v 25 amp.
TURBS
Old 06-11-2014, 10:18 AM   #14
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Ok, that's a bummer.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is online now   Reply With Quote
Old 06-11-2014, 10:23 AM   #15
Ford Idaho's Avatar
My set up.
As I said works great.
Old 06-11-2014, 10:30 AM   #16
TURBS's Avatar
Yes your's is / was like mine.
4 Prong 240/120 30 amp.
But that 30 amp is rated only at 240 v
With the floating neutral.
You've got around 15 amps while using the 120 side.
TURBS
Old 06-11-2014, 10:38 AM   #17
TURBS's Avatar
Ford Idaho what gennie is that?
TURBS
Old 06-11-2014, 10:39 AM   #18
Kyjellywhite
What's got me stumped is the three prong twist receptacle is in the "120" box but if you look close and read the receptacle it says "250". Guess I need to put a meter on it to see what is actually coming out.
Old 06-11-2014, 10:46 AM   #19
TURBS's Avatar
In order for it to be 250v it would need "4" plugs.
Hot
Hot
Neutral
Ground
It only has 3
Hot
Neutral
Ground
As shown in the diagram post on page 8 of manual.
That plug you have is a rarity on most gennies.
While good your limited to 25 amps.
I'll post a handy chart so you can see what you can run and not run at the same time.
Remember your converter is a constant draw no matter what so those amps come off the top before any other 110 electrical device is used.
TURBS
Old 06-11-2014, 10:49 AM   #20
TURBS's Avatar
normal appliance amp draws
Look here
TURBS
generator
