Old 06-11-2014, 08:20 AM   #1
Kyjellywhite
kyjellywhite's Avatar
Another generator question.
Please bare with me as I know there are a lot of these questions like this one out there but I have not found any answers.
I have a 2015 Sierra 376bhok. It is 50 amp service.
I just purchased a new ETQ DG4LE 4,900 Watt 8 HP 296cc Diesel Powered Portable Generator With Electric Start. I purchased this because 1. Cost (got it super cheap) 2. Diesel was a must for me ( I have a 50 gallon aux diesel tank in the truck) 3. Didn't care about the db level because I will only be using it while boondocking.
So now my predicament. The receptacles on the gen are 1. 120v 20 amp 2. 120v 20 amp 3. 120/240 20 amp and 4. 250w 25 amp.
Obviously, the only thing I can plug into without frying the fifth wheel is 120v 20amp but that barely powers my 15,000 btu a/c. Anything added will trip the c/b.
Is there anyway to install a 30 amp receptacle? I'm not looking to power everything on the mother ship with 30 amps but I am use to living on at least 30amp.
I have a attached a link to the owners manual if that helps http://www.internationalpowerproduct...DG4LEDG6LE.pdf
Again, any advice you guys could give to save me money and keep me from buying another gen/resolve this would be appreciated. Thank you in advance!
kyjellywhite is offline   Reply With Quote
Old 06-11-2014, 09:14 AM   #2
Ford Idaho's Avatar
A picture of the receptacles would help id them better.
Do you think something like this would work?
Rodale 1 ft. 30 Amp Generator Male 4 Prong to RV 50 Amp Female Adapter-G30AM450AF at The Home Depot
Old 06-11-2014, 09:22 AM   #3
TURBS's Avatar
No that will not work.
I've been down this road...
My generator has 2 20 amp receptacles and "had" a 240/120 v "rv" outlet.
The 240/120 outlet has a floating neutral and is rated at 30 amps "on the 240 v side" and only "15" amps on the 120v side.
Deceiving I KNOW!
I had a "local" generator guru "rewire" my generator and install a RV 30 amp outlet.
OP I could be wrong but 20 amp may be the most you'll get out of this generator.
The a/c can draw up to 18 amps to start "higher if super hot out" and will run in the 12 -14 amp range.
TURBS
"Sabre owners united"
Old 06-11-2014, 09:24 AM   #4
Ford Idaho's Avatar
Deceiving I KNOW!
TURBS
Ah.
I got the 30 amp version for mine, works great, thought it might help.
Old 06-11-2014, 09:28 AM   #5
TURBS's Avatar
Op would you like the contact info for my generator guru to see if he can help?
TURBS
Old 06-11-2014, 09:28 AM   #6
Kyjellywhite
I figured it would have to be re-wired to some aspect just wasn't sure if I could do it or needed a pro. I guess I'll try to find a generator pro in the area. You are so right Turbs! Deceiving!
Old 06-11-2014, 09:30 AM   #7
Kyjellywhite
TURBS
That would be wonderful. At least he will know what I'm talking about instead of just getting a blank stare from a stranger around here.
Old 06-11-2014, 09:36 AM   #8
TURBS's Avatar
I called Honeywell about it and they told me that this is the perfect gennie for a camper.
I told them they were full of crap!
My gennie is in the neighborhood of 6800 watts and it won't run my a/c or barely did.
They said my a/c must be bad.
Really?
He explained there was 30 amps available that it should be fine.
After talking to my gennie guy he explained to me that 30 amps is only available on the 240 v side and half that on the 120v side.
Cost me $150.00 to make it work.
I've been trouble free for 2 years.
TURBS
Old 06-11-2014, 09:41 AM   #9
Kyjellywhite
Really?
TURBS
I would totally be ok with paying a $150 to get this how I want it, considering what I have invested in it. Time to try to find some gen guys in the yellow pages I guess.
Old 06-11-2014, 09:46 AM   #10
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
To me this looks like a regular twist lock receptacle (page 8 in your manual), you should be able to find an adapter at RV dealerships or online.
Or am I missing something?
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
generator
