I’ll attempt to help if possible, however, I am not sure I or you are aware of what you are possibly undertaking. Perhaps others more knowledgeable than me, or experienced, and capable can advise how to accomplish the task at hand like falling off a log. Frist off, if a “RV” receptacle exists with USB outlets and fits in the space of a standard RV AC outlet, buy that and stop reading here.
If considering installing a residential AC outlet with USB “A” and/or “C” charging ports or any USB charging port, keep reading. If there is space to install a residential receptacle box in the wall or cabinet location, then an AC outlet with USB charging capability may be accomplished in most modern RV’s.
See these photos for installing a residential USB receptacle in place of a standard “AC Recreational Vehicle Receptacle.” As RV's do not use receptacle electrical boxes like residential or commercial building. In RV’s the non-metallic cable is terminated directly inside an RV AC receptacle its self and not installed in an electrical box.
