Old 07-08-2014, 03:56 PM   #1
JCamper's Avatar
Any electrical smart folk out there..
So camping this weekend I bought this outlet with the intent of hooking it up to a 12v deep cycle battery and running a CPAP machine that has a 12v plug.
I get 12.79 volts to the recepticle when connected to the battery, but when I plug in the CPAP or anything else for that matter (phone charger) I get nothing.
Actually I get smoke and swear words when I plug in the phone charger!
Any ideas?
The folks at State Trailer Supply said that if I have an appliance that runs on 12v this outlet with the alligator clips will do the job.
Does it need to be grounded somehow?
ID:	57632   Click image for larger version
JCamper is offline   Reply With Quote
Old 07-08-2014, 04:01 PM   #2
TURBS's Avatar
Id say ....
Its hooked up backwards.
Or the outlet is junk.
Old 07-08-2014, 04:17 PM   #3
prof_fate's Avatar
ac can work either way..DC is directional. Pos and Neg have to be right. if not you may get smoke or blow a fuse or melt things. Less often you get nothing happening (like putting batteries in wrong)
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 07-08-2014, 05:01 PM   #4
SYE
SYE's Avatar
Make sure that it was hooked up to the battery correctly. + goes to the red clip, - to the black clip. Do not go by the colors attached to the battery I think on mine a white wire is attached to + and the black to -. It could be a faulty plug as well.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 07-08-2014, 05:27 PM   #5
Batts-toy's Avatar
Once you have the wires attached correctly as stated above confirm how many amps the CPAP uses and that it or whatever else you are operating does not exceed the limits of the little adapter and clips.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 07-08-2014, 06:44 PM   #6
SYE
SYE's Avatar
I know that when I am dry camping my CPAP runs off of my 375 watt inverter.
Scott & Vicki
Old 07-08-2014, 07:20 PM   #7
VinceU's Avatar
Any ideas?
No, but what you are having is severe voltage drop due to small wire, toy DC recep and Alligator clips. All the above lead to high resistance and with low current will cause the voltage to drop before the load. Get a heavy duty 12VDC recep, #12 stranded wire and a full spade terminal to bolt to the battery and it will work.
Old 07-08-2014, 07:35 PM   #8
Herk7769's Avatar
Yes, our CPAP is 200 watts also. 200/12 = almost 17 amps.
That lamp cord wire set is rated at about 8 DC amps.
Also check the polarity of the connector using a volt meter.
Some of those made in (non) USA locations have the polarity reversed in the connector.
The center should be the positive and the barrel should be the negative.
HAM CALLSIGN - KC3FFW
Old 07-08-2014, 11:29 PM   #9
JCamper's Avatar
I've checked the wiring all the way from the battery to the fuse but not from the clips to the barrel itself, that's a good point HERK thanks. It also makes sense that the wiring would be too little to handle a load, but even the cell phone charger without a phone attached smoked. But still a good point. I'll look for a more heavy duty line.
Old 07-08-2014, 11:48 PM   #10
Evereddie's Avatar
...but even the cell phone charger without a phone attached smoked.
Again, that sounds like reversed polarity.
Evereddie is offline   Reply With Quote
electric, electrical
