Old 08-04-2015, 11:49 AM   #21
oldsmasma's Avatar
Our motorhome is plugged in all summer between trips. We have a dedicated 30 amp plug in for it. The fridge is always cold and stocked with the basics. Makes getting ready to go a snap. By the way - DH is an electrician.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
oldsmasma is online now   Reply With Quote
Old 08-04-2015, 11:53 AM   #22
When we built our house had a 30amp service box put in on the back corner of the pad where we park the Grey Wolf. Best money I ever spent. On that rare occasion when we have overflow guests, can put them in the RV even in triple digit weather and they still have A/C. Before I added solar panels to RV roof, it also ensured I was topped up electrically for each new trip. VR, Mags
MagsnDeb is offline   Reply With Quote
Old 08-04-2015, 12:05 PM   #23
You can leave the trailer plugged in all the time. If you do, be aware that some converter/chargers will boil the water from the battery. Check the battery periodically. Start with checking once a week. When you get familiar with how often you need to water the battery, you can extend the checking period. If you have a good charger/converter, you may only need water once a year. The WFCO charger/converter that came with our trailer did not do a good charging job, and we replaced it with a charger from Progressive Industries. Now no battery boiling issues.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 08-04-2015, 12:31 PM   #24
Travler's Avatar
I leave mine plugged in also. The only problem could be if your converter is not the type made to stay plugged in. Some will overcharge the battery. Most of the new units are okay but it is a possibility.
Travler is offline   Reply With Quote
Old 08-04-2015, 12:33 PM   #25
X2
I keep plugged into a 30 amp receptacle with EMS protection and Progressive Industries multi-stage converter keeping the batteries at trickle charge. Only needed to add a tiny amount of distilled water to each cell for the year.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 08-04-2015, 12:48 PM   #26
There is no problem with keeping it plugged in. BUT, be sure to check the battery or batteries periodically for depletion of water. The small amp chargers built in to the power centers are not regulated and will use up water over time.
hillsdaletc is offline   Reply With Quote
Old 08-04-2015, 12:53 PM   #27
bpdlk33's Avatar
I have kept trailers plugged in for over 20 years and never had a problem.
bpdlk33 is offline   Reply With Quote
Old 08-04-2015, 01:05 PM   #28
sail2liv's Avatar
Ours has been plugged in for 3.5 years, except when traveling and boondocking.....we have always had a surge gard, imo a must........if you don t have one, get one....sooner than later.....one bad plug in can bring headaches for many years.....as incorrect volts is cumulative damage wise good luck
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 08-04-2015, 01:07 PM   #29
Evereddie's Avatar
Yup. Plugged in 24/7 365, at least when she's at home.
I highly, highly, HIGHLY recommend getting a power management system.
Evereddie is offline   Reply With Quote
Old 08-04-2015, 01:39 PM   #30
7 Year Class A RV'er
Our MH stays plugged in in the driveway all the time we aren't traveling in it. A/C is running, fridge turned on, etc. We even set the front heat pump to automatically heat if needed (we're in Florida). Actually seems to keep everything inside a lot nicer, no smells, etc. I have heard of folks putting space heaters inside the unit and that can lead to some issues as they can put a pretty good load on an electrical system and are always a fire hazard.
2015 Legacy SR340 360RB
camper
