Old 08-04-2015, 05:53 PM   #41
My old motor home would cook the batteries if left plugged in full time, on board charger would not cut back on charging amps. Put it on a timer, only ran 2 hrs a day to keep batteries charged. Don't know if on board charger was defective or not, but timer solved the problem.
pdqparalegal1 is online now   Reply With Quote
Old 08-04-2015, 06:06 PM   #42
Ours stays pluged in 24/7 but frigge/TV/TV Stereo not activated breaker(s) off
Jim in Halifax is offline   Reply With Quote
Old 08-04-2015, 08:42 PM   #43
I've had 4 different campers plugged-in for more than 15 years and never had an issue yet.
magpi26 is offline   Reply With Quote
Old 08-04-2015, 10:30 PM   #44
Originally Posted by Evereddie View Post
Because almost all trailers don't have a total battery disconnect switch people leave them plugged in to keep the battery from running down. Because the LP gas detector is hooked straight to the battery it will drain the battery down to nothing if the trailer is left un-plugged. Unhooking the battery will solve this but that's a lot of hassle,. easier to leave it plugged in. It will also keep the battery totally charged.
Some people leave their trailer plugged in because they might be running something inside like a dehumidifier or heater in the winter.
Okay, I think I see some of the reasoning. We've been RV camping for over 20 years and I keep it unplugged, pull the battery out and cover it. Never had a problem, so I was just curious about hearing so many keep it plugged in. THANKS
Mr. Camper is offline   Reply With Quote
Old 08-05-2015, 07:05 AM   #45
Wolverine 1945's Avatar
Not sure why you would leave the fridge on ???
Unless you are using it !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-05-2015, 07:17 AM   #46
We always did that for years with our TT,,, removed battery,,, covered unplugged !!! This last winter was our first winter with MH,,, left it unplugged for about 5 months,,, started the motor a couple of times,,, but when I went out in the early spring,,, every thing was Dead,,, took days to get the batteries charged back up !!! I then put a battery maintainer on the truck battery !!! Thinking I may leave it plugged in this winter,,, with surge protector !!!
Old 08-05-2015, 07:53 AM   #47
Tom48's Avatar
I agree. If you run it long term, and want stuff to last, good surge suppressor and a four stage converter charger would be best.
I would hate to run that little frig 24/7 unnecessarily. Especially not in heat, as it makes plenty of heat by itself, and probably will not last forever like a residential, compressor type.
Tom48 is offline   Reply With Quote
Old 08-05-2015, 08:06 AM   #48
Originally Posted by bob caldwell View Post
Take a volt meter....place neg. Lead on batt. post, take pos. lead and touch to battery case over by/around the pos. pos . If batt. dirty, it will surprise you .
Right on Bob,,,
I found that to be very interesting on my tractor Batters !!!
Old 08-05-2015, 08:08 AM   #49
I really do not see any reason to leave a TT plugged in all winter here,,,
Remove battery,,, place it in the basement until Spring !!!
Old 08-05-2015, 10:25 AM   #50
A protector typically used in campers (ie Progressive) are for electrical anomalies completely different from the completely different transient (called a surge) that exists in homes. Meanwhile plug-in protectors do not claim to protect from either of those anomalies.
The word 'surge' is subjective. It can even describe a high voltage, a high current, a low voltage, noise, or a low current. Each and completely different device (all called surge protectors) must be defined by which anomaly is a concern. That means numbers.
westom is offline   Reply With Quote
camper
