Old 08-03-2015, 09:11 PM   #1
Wobbles's Avatar
Any risk if I leave camper plugged in?
I am thinking about leaving the TT plugged into an outside GFI outlet on my house. I have done this for more that a week at different times, with no noticeable trouble. A buddy recently advised that I may burn up something.
I accept that the house could send a bad jolt to the rig, but still, short of that (no pun intended), Is there a danger? If I did that and kept the fridge on electric, does it stand to suffer?
I stopped doing this on my buddy's advise. Can anyone share caution/experience advise?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 08-03-2015, 09:19 PM   #2
I don't do it only because my camper is parked about 200' from my house and I have no electric there, but a buddy of mine leaves his plugged in all the time to a receptacle in his garage. I have read of several people on here doing it also. I think you will be fine.
Get yourself a progressive industries EMS and then it will shut down if there is a power issue. (I haven't gotten one of those yet, but it is on my list)
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 08-03-2015, 09:20 PM   #3
Left Coast
365 24/7. Not a problem
Old 08-03-2015, 09:28 PM   #4
WFD
No reason to stop at all...it's made to be plugged in. Just don't expect to run much, won't be enough juice to run your a/c. If you are concerned about power from the house you could buy a surge protector, which is a good thing to have for campgrounds anyhow, then you will be protected. For not all that much money, you could install a 30amp plug for your RV at your house and then you could run more and even your a/c if need be.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 08-03-2015, 09:34 PM   #5
Dennis and Julie's Avatar
We keep ours plugged, never had a problem.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is offline   Reply With Quote
Old 08-03-2015, 09:47 PM   #6
davel1971's Avatar
mine stays plugged in from March to November every year
David & Lynn
Old 08-03-2015, 10:24 PM   #7
Left Coast
If you have a 13,500 a/c, 20 amp circuit from house will run it....but a hard wired surge protector is really advised....Am on a cross country trip right now and am not worried about anything getting toasted. Don't like the smoke gennie.
Old 08-03-2015, 10:34 PM   #8
rsdata's Avatar
I do THIS^^^
you will deplete water from the TT battery on constant charge,
not a problem but, pop off the caps on the battery(s) and refill with distilled water every 2-3 months... to the bottom of the split ring on the fill hole
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-03-2015, 10:34 PM   #9
B and B's Avatar
I leave mine plugged in at Home, no surge guard. The rest of my house does not have any Surge Suppression. Underground delivery and many transformers before lighting can enter the system. The park we stayed at last night was a mess of wiring and the power box I had the 30 amp breaker was falling out of the box, that worries me.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 08-04-2015, 07:19 AM   #10
waiter21's Avatar
Mine stays plugged in 24/7. I have a 4 stage converter that will maintain the batteries without boiling them.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
camper
