Old 10-04-2016, 08:16 PM   #1
Any suggestion on an electric heater?
2017 FR3 We tried a 1500 w electric heater and the circuit breaker trips when refrigerator starts. Any suggestion on a low wattage heater? We have tried different outlets (which are limited).
Stknutti is offline   Reply With Quote
Old 10-04-2016, 08:54 PM   #2
Iggy's Avatar
1,500 watt heater at 115 volt pulls 13 amps and if I'm not mistaken all your circuit breakers are 15 amp.
You could bet a 1,000 watt heater which may not trip the breaker.
You need to put it on a dedicated circuit breaker.
Have you tried the one that powers the microwave?
Just don't use the microwave when the heater is on.
If you can't find anything you just may have to add a dedicated circuit breaker in the panel with it's own outlet.
2012 Georgetown XL - 378TS
Iggy is online now   Reply With Quote
Old 10-04-2016, 10:20 PM   #3
HONDAMAN174's Avatar
Does your heAter have a low setting? Most are 750 watts. We have be running ours for four days on low and furnace rarely kicks on. Temps are in the twenties at night.
And if have the ability, run a 15 or 20 amp extension cord to your pedistial and create your own extra circuit.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 10-04-2016, 10:41 PM   #4
Briorick's Avatar
Just a suggestion here. We have a Mr. Buddy Heater that we bought years ago when we had our Pop Ups, and still use to this day. Works great, and is temperature controlled. Uses small LP canisters, so no electric required. Might want to give these a look.
Mr. Heater Portable Buddy Propane Heater — 9000 BTU, Model# MH9BX | Propane Portable Heaters| Northern Tool + Equipment
Rick & Brian
1 Happy Camper Pup ( Mya )
2016 Salem Cruise Lite 171RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is online now   Reply With Quote
Old 10-04-2016, 11:21 PM   #5
I use a electric bedroom heater (very quite) on medium heat and it runs 750 watts. It runs all the time when the temps are cold but there is no issue with breakers. Are you using a compressor type refrigerator? An RV frig should only draw 2 to 3 amps and there should not be a starting surge.
markb422 is offline   Reply With Quote
Old 10-05-2016, 05:27 AM   #6
Many have installed or had a electrician install a "Thru wall dedicated circuit" they are the same type used on boats! Connect to the power pedestal with a HD extension cord! Very easy install! Youroo!! Pic of outside power inlet above BTR inlet!
Old 10-05-2016, 05:41 AM   #7
waiter21's Avatar
When we are plugged into shore power, we have a small 900 watt version, If yours has two temperature settings, the LOW setting is usually about 1/2 of the high setting. ALSO, the fan on ours would switch on and off with the heating element, I modified it so the fan runs all the time.
As someone mentioned, When not on shore power, we have a small Mr Buddy that I modified to use house propane instead of the small 1lb bottles.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 10-05-2016, 05:54 AM   #8
+1
I did this on my Solera. Only problem was that I wasn't comfortable drilling a hole (blindly) on the driver's side, so I did the install on the passenger side. My setup runs up to 20 amps to a single duplex outlet and includes a dedicated circuit breaker. Probably cost $50 for all the bits and pieces.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 10-05-2016, 06:04 AM   #9
jeff
jeff64's Avatar
Personally, I'm not real keen on the use of non-vented propane appliances in a TT when I'm snoozing due to CO emissions. I do use a "bathroom" electric on the lowest heat setting to augment the operation of the Lp furnace, just as the other posters recommend. Besides blowing the breaker on hi when anything else that demands higher current kicks on, the power cord will warm up to the point that it makes me uncomfortable knowing that's going on while I'm napping. Spend the extra couple bucks on the furnace operation and be safe. Happy fall camping
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-05-2016, 12:28 PM   #10
Left Coast
Oil filled radiator type
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
electric, heater
