Old 07-04-2019, 11:23 AM   #1
Awning LED Lights not working 364TS
Does anyone know where the fuse is for the LED awning lights? they are not working. I have swapped out switches and still nothing. I'm showing ~4V for the switch but then when you turn the switch on nothing. Trying to trace the lines back to ohm them out but they of course are so far behind the cabinets I can't see where they go.
Walte1fr is offline   Reply With Quote
Old 07-04-2019, 04:40 PM   #2
Dan0753's Avatar
On mine there is a plastic outlet cover on the inside higher up on the wall towards the front of the camper. Itís close to the height of where the lights would be. Thereís wires in there and a fuse.
Dan0753 is offline   Reply With Quote
Old 07-04-2019, 05:05 PM   #3
Thanks. I ended up tracing it back to a connector they put in the inverter compartment that was corroded and the wire was broke. That was a long day haha
awning, led, light
