Old 11-22-2015, 04:33 AM   #1
Bad batteries or converter
I'm pretty new to the trailer thing, and I believe I either have bad batteries or converter. I'm plugged in at a rv park and my light keep dimming and frig will turn off when my furnace turns on. Also when I press the battery button to see the charge it says empty. But I don't know if that's just because I'm plugged in and not using battery.
Atgibson88 is offline   Reply With Quote
Old 11-22-2015, 05:24 AM   #2
Witch Doctor's Avatar
It should read full when plugged in, It's not your batteries but your convertor. Do you have a multimeter with you? Measure the voltage going to the convertor and going out. I think I have a diagram how to do it. If you see it below I found it. Sorry both attachments are the same. You should have also gotten something on your convertor it will also be in there on testing it.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 11-22-2015, 03:55 PM   #3
A defective battery can pull converter down. As mentioned previously disconnect batteries and then plug camper back in and test voltage out of converter. Should be close to 13.6 volts. Large variations from this would indicate a converter problem unless something happened to the wiring. You could also take batteries to an auto parts store, most will test for free.
Let us know how you make out!!!
mfMcFroggierPod is offline   Reply With Quote
converter, battery
