Old 11-17-2019, 05:32 PM   #1
bathroom motion light has no switch
2020 Grey Wolf toy hauler has no switch to change motion detector in bathroom. Light goes off while showering with no control over changing. Is this a manufacture screw up?
Sandie is offline   Reply With Quote
Old 11-17-2019, 08:48 PM   #2
Some motion switches have a section of the switch that you press to override the motion detection. It's usually the bottom portion of the switch.
Can you post a picture of the switch.
Gotta go campin!
Old 11-17-2019, 10:06 PM   #3
Pict of light
Old 11-18-2019, 10:44 AM   #4
That's different than any I've seen. Can you take it down and see if there's any markings or numbers on it?
Gotta go campin!
Old 11-18-2019, 11:08 AM   #5
I had a motion sensing light 'similar' to that one. (not exactly the same)
The center button/sensor was a switch.
Push it once it was in motion sensing mode.
Second push turned it on all the time and the third push turned it off completely.
Mine looked like this... again, similar so maybe the center sensor is a switch too?
It also 'appears' not all the LEDs are lit up (inside the lens) in your photo making me believe there is a switch option for Low/High as well.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 11-18-2019, 03:39 PM   #6
We have tried everything..going to ask dealer tomorrow, will let u know. So far nothing has worked and doesnt want t be removed from wall..🤦*♀️
Old 03-17-2020, 12:19 AM   #7
So I have the same model as Sandie.. first time for my wife to use the shower, and she used it at night.. and the motion light went off after about 2 minutes lol. Sooo I set about trying to find SOME kind of info on this LED. I guess since I'm a new user I can't attach images yet but it's made by Dreamlighting. The tag on the wire in the wall says 703003-4K-SENSOR and 2019-6. Uses .24W @ 12v. Anywho based on the logo on the tag, their website is from Australia (.au domain name) and it's definitely not very helpful.
incognito53 is offline   Reply With Quote
Old 03-17-2020, 12:26 AM   #8
Figured out how to attach I have the same model as Sandie. So we found out the hard way to use caution when taking a shower at night, as it turns off after 2 minutes, or right when you have soap in your hair and eyes. I didn't see any obvious adjustments, but I did figure out that it's made by Dreamlighting and looks to be model 703003-4K-SENSOR.. that or 2019-6. Their website ends in .au which means Australia, but the website doesn't seem to be of much help
ID:	225294   Click image for larger version
ID:	225295   Click image for larger version
ID:	225296   Click image for larger version
Old 03-17-2020, 08:44 AM   #9
WoodLark-SC's Avatar
This is by design to encourage you to take shorter showers and waste less water!
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
WoodLark-SC is offline   Reply With Quote
bathroom, light, roo, switch
