Old 01-13-2019, 09:28 PM   #1
Batteries
I have a double battery setup in my 2251 forester. When fully charged volt meter reads approximately 12.6. When I check volt meter after 24 hours it reads 12.2 to 12.0. I have the battery cut-off switch turned on and the tv plugged in so I know there is some draw on the batteries but surprised that much. Is this typical or are the batteries failing after 9 months? Thanks, Jerry.
dumboatt2 is offline   Reply With Quote
Old 01-13-2019, 10:29 PM   #2
Could be either, or both.
Have the batteries load checked.
Then comes the hard work of what is drawing the current. If you can use an ammeter check each DC circuit at the fuse panel.
Fred W
Old 01-13-2019, 10:37 PM   #3
rsdata's Avatar
you need something like this to test the ability of your batteries to deliver consistent power after being loaded and drawn down... also you may have other parasitic loads besides just the TV such as the CO monitor...
It would be nice to know the amount of current in amps that are being pulled by the batteries when connected. Most cheap volt-meters will allow you to put them in series with the battery cable and measure up to 10 amps of current draw. If you have one then use it to measure and not guess what the current draw is.
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 01-13-2019, 10:43 PM   #4
You say the battery cut off is switched turned on.. make sure is is switched to off. Its kind of misleading as its labeled battery cutoff so it seems to work to cutoff the battery it must be on. So to switch off battery tirn to off...
2016 Siverback 33IK
dalford is online now   Reply With Quote
Old 01-13-2019, 11:39 PM   #5
Use a meter and measure the current being delivered by your batteries with everything supposedly off.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
batteries
