Old 06-25-2016, 02:05 PM   #1
Batteries & City Power
We're newbies to travel trailers. My TT has 2 batteries connected in parallel. I'm trying to determine what to do between outings, which could be up to 3-4 weeks. Do I plug the TT back into my home AC while it is sitting on my RV pad or hook the batteries up to a Battery Tender? I have seen contradicting comments. Some say if the TT is connected to city power for an extended period of time I might fry my batteries. According to my owners manual "when not in use, keep hooked up to AC if possible and let the converter first charge and then maintain the battery charge". I will move the batteries to my garage during the snowy winter here in Utah and keep them on the Battery Tinder, but what about summertime?
Ted & Gail
2016 Salem Cruise Lite 201BHXL
2012 Chevrolet Silverado 1500
tgduffy is offline   Reply With Quote
Old 06-25-2016, 02:11 PM   #2
bikendan's Avatar
Newer RVS have very capable 3 stage converter/chargers.
We've been plugging our shore cord into a home outside outlet for 10 years now.
NEVER have needed a separate battery charger.
And the batteries are at least 8 years old now.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-25-2016, 02:30 PM   #3
Bluepill's Avatar
I had 3 one-year-old batteries dry out from being connected to the factory-installed 4 stage converter/charger for 5 months in storage. I now let that unit fully charge the batteries for a few days, then turn off the power to it and rely on a maintainer. No problems since then.
2008 Itasca Meridian 37H
Old 06-25-2016, 03:53 PM   #4
Leave it plugged into shore power between outings. Check battery fluid after one week, if it is not bubbling vigorously then all is good.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is online now   Reply With Quote
Old 06-26-2016, 01:42 PM   #5
I just hit the DC disconnect the batteries stay fully charged for six months at a time. Assuming they are fully charged at the time I park it. Been doing this for years. Never had a battery issue
Tomgky is offline   Reply With Quote
Old 06-26-2016, 05:10 PM   #6
camaraderie's Avatar
Neither. Plug in overnight when you get home....then unplug and disconnect the negative wire from the batteries to ground.
In one month your 100% charged battery will be no less than 85% charged in "room temperature weather. There is no need and some risk to keeping a unit plugged in. Battery tenders are unnecessary unless you are going awol for 90 days or more.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 06-26-2016, 06:56 PM   #7
X2. But depends a lot on what part of the country you are in. We are on the west coast close to Vancouver BC, Only see a dozen nights of frost most years. Isolate the batteries in the fall and most years they are 3/4 Charge in the spring. Hook them up to the generator for a couple of hours and back to full charge. I always disconnect the batteries when we store, even if it's only a week. Stops parasitic drain. Our batteries are on thier fifth season.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 06-27-2016, 06:34 AM   #8
Wolverine 1945's Avatar
I dough very much if your plan would work in Michigan ???
Or any where in the North Country !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-27-2016, 07:26 AM   #9
I assume you are referring to the cold weather. Actually batteries hold their charge FAR better...2-3 TIMES better in cold and freezing weather than in summer heat. Getting a car started is harder....but keeping a battery full is easier. You may expect a disconnected battery to lose roughly 5% of charge per month in winter vs. around 15-20% in summer.
The KEY is a FULLY charged battery to avoid freezing. A fully charged battery will not freeze till -91 degrees. At 62% charge you're good to -16 degrees and at 40% charge you will freeze at +5 degrees.
________
Cam
Old 06-27-2016, 07:41 AM   #10
Thanks Cam for the Info,,, sounds like you know Batteries !!!
power, battery
