11-08-2015, 08:23 PM
Batteries cooked
I have a 2013 Sunseeker 3170DS, Last winter I left the unit plugged in to 30 amp power, in it's enclosed garage, for approximately 2 weeks and found the unit full of odor, battery, and alarm chirping. Batteries were cooked. WHY ? I thought motorhome could be left plugged in to outside power indefinitely and would be OK. Replaced batteries and now afraid to leave unit plugged in. I always get better advice on this forum than calling the dealer
11-08-2015, 08:29 PM
I had the same problem. Toasted 3 batteries that were less than a year old. I now use only a small battery maintainer for storage. Small maintainers cannot over charge your batteries because they only supply a small amount of current.
This is the unit that I use:
http://www.amazon.com/Yuasa-YUA12010.../dp/B00HZTDKZG
The "Battery Tender" brand has failed in service for two friends, so I chose the Yuasa brand since they make excellent batteries for motorsports.
11-08-2015, 08:35 PM
Who Dares, Wins
If the charger is not "smart" you will cook them like hotdogs.. Need to see what model your converter is the see how smart ut is..
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
11-08-2015, 08:57 PM
Citrus County, Fl.
Okpete, since your unit is a 2013 you probably have a WFCO converter. In my opinion they don't do a real good job of conditioning or charging your battery. Foresters and Sunseekers now use the Progressive Dynamics converter and transfer switch. In storage mode the voltage drops to 13.2 volts so as not to overcharge the batteries. Also, every 21 hours for a period of 15 minutes it charges at 14.2 volts which prevents battery stratification & sulfation - the leading cause of battery failure per the manufacturers literature.
http://www.progressivedyn.com/pd4600...placement.html
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
11-08-2015, 09:01 PM
First thing I change on all of my campers is replace the power converter/charger with a Progressive Dynamics Intellicharger with smart wizard pendant....never had an issue with overcharging when camper is brought home and plugged in.
11-08-2015, 09:14 PM
The WFCO converter does not have a maintenance mode. The lowest level is essentially a trickle charger which will slowly boil off battery water. Once the water gets low the battery will cook. You have three choices.
1. Replace the converter with Progressive Dynamics converter.
2. Use a Battery Tender (TM) to maintain batteries.
3. Use the WFCO converter, but check battery water ever 2-3 wks.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
11-08-2015, 09:37 PM
Karen, Pete & Chloe Kat
2016 Solera 24 R Batteries are NO NAME!!!
My post is about my batteries which are just over 8 months old Have a Dec 2014 sticker)! The RV was delivered in early July 2015.
I had to remove the batteries to re-arrange the battery Box; the wires almost completely covered the water vents.
But BOTH batteries are showing signs of over charging (the cases have small bulges,
But what really makes me angry is that they are NO NAME! They are not any name Brand, there are absolutely no markings except some small numbers in the plastic! No Amp Hour ratings, No Nothing!
You pay $100 Grand and FR gives you #$%%^&&** batteries!
Really sucks!
sanpedroflyer
11-08-2015, 09:38 PM
Who Dares, Wins
It's all about the bottom line...
2015 Chevy HD D-Max
11-08-2015, 10:02 PM
Thanks for all the good info, I agree with 'flyer, spend a bunch and get no name batteries and a converter that cooks them. Seems very odd. So here is another question, can you leave the batteries in place and use a battery tender? If so, I woulg assume you connect tender to coach posative onone battery and negative on second battery ?
11-14-2015, 06:20 PM
I wouldn't worry about which positive and which negative post to which to connect the battery maintainer. The current is small and the cables connecting the batteries together are large so the difference in current going to the batteries will be neglible.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
11-14-2015, 06:42 PM
Really sucks!
sanpedroflyer
Are you surprised. You probably also got a no name antenna and no name tires.
TST Tire Monitors
2 100W solar panels
11-14-2015, 06:58 PM
Location: Chicago, Rochester now GA/SC at Lake Hartwell
I have no-name sealed batteries under the stairs of my other RV...an older class "A" Damon. First thing I did was change the converter from a primitive and tired Magnatek to a 55 amp WFCO smart charger. It has three levels of charge. The lowest is a maintaining 13.2vdc.
I've not had a 12volt issue of any sort in three years with the two chassis batts and the engine batt. A modern WFCO should be fine.
Some ok with WFCO, some not. A lot of personal preference/convenience.
My new XLR 415 has a Progressive. It has a transformer that hums so loud with or without load I will have to switch it out. I will not let me rest.
Some ok with Progressive, some not. A lot of personal preference/convenience.
One poor performing cell in a bank of batteries will bring any converter to boil the batteries.
In three RV's I've purchased replacement WFCO's for the first two. In my third and newest I have to replace a Progressive.
All my RV's are connected 24/7...never boiled a battery. Most of my batteries last >7 years. Mtcyl batts around five as I have them on desulphators 24/7.
A voltmeter is your best friend.
Converters are similar to oil forums IMHO.
2019 Sandpiper 379FLOK, F350 Lariat 6.7 DRW, KN4YBP APRS, NRA Benefactors.
11-14-2015, 07:00 PM
I connected w coachmen and they advised me not to use the converter to maintain the batteries during extended storage. They suggested disconnecting the batteries, remove them to a warmer area and put on a maintainer OR leave in coach, disconnect batteries from the coach by removing the +ive cable/wires. Make sure fully charged (if being left for a month or 2) or put on a maintainer and can be left for months
Since I have a solar panel, I disconnect +ive terminal from coach and let the solar controller float charge the batts. I did check the battery fluid levels and if a nice day will check again in a couple of months. Now have a Trik-L-Charger connecting to the chassis battery to keep that baby healthy.
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
