Old 09-17-2015, 03:51 PM   #21
Kenny kustom's Avatar
If everything is turned off in the camper... There shouldn't be any draw. Thus no arc.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-17-2015, 04:28 PM   #22
2008 F350 CCSB V10
2016 Sabre 36QBOK
If your batteries are low the converter will start up right away, thus causing an arc.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 09-17-2015, 04:33 PM   #23
But the trailer has been hooked up to my truck for how many hours?
Anywho. Just a difference of opinion.
Breakers are not designed to be used as a switch, unless marked for switch duty.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 09-17-2015, 04:57 PM   #24
Oaklevel's Avatar
2008 F350 CCSB V10
2016 Sabre 36QBOK
2
It is not likely that everything is off or can be turned off. Do you also switch the water heater off behind the cover? The converter? do you turn if off??? or trip its breaker?? If you don't then something is always on on the 110V side when you plug into the pedestal.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 09-17-2015, 05:06 PM   #25
"This is all correct and I did this too. Now that I have installed a Progressive power management system I don't need to, the progressive does it for me. It waits 10 seconds or so to apply power to the trailer after the plug is put in. No arcs."
Progressive recommends the post be off before plugging in the EMS unit, then energize the post, give it the two minute check period, before plugging in the RV.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-17-2015, 05:09 PM   #26
Left Coast
Truck is 12 volts.... land line is 120 volts. Charge rate from tv isn't much. It's a whole lot less trouble to turn off pedistal breaker...after all, you've got the lid open. If it's a hard wired unit you need to plug in, turn on breaker, before the EMS can do it's thing
battery
