Old 09-16-2015, 07:31 PM   #1
Sagecoachdriver's Avatar
Batteries drawing after disconnect switched off
I was installing my Xantrex battery monitor system on my Forester's 2 group 27 batteries. I had the kill switch engaged. When the Battery monitoring system was installed, it showed .1 amp draw. When it was in my Winnebago, it showed 0 zero with the battery disconnect switched. Should be zero in the new Forester. That means when batteries are disconnected between trips, the draw will be 19 amps per week. Good thing I keep it in my driveway instead of a storage lot as it would be totally dead in 3 months. The monitor itself draws 18mA in power saving and 32mA normal monitoring, so I don't thing it's that.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-16-2015, 07:40 PM   #2
davel1971's Avatar
not sure how you are coming up with a "amps per week" figure. Any amp draw at all will drain battery over time of course. Why not just put in a mechanical disconnect switch instead of one that uses power to save your battery
David & Lynn
Old 09-16-2015, 08:36 PM   #3
Left Coast
Lots of little draws that the factory switch doesn't deal with.
Old 09-16-2015, 09:09 PM   #4
At .1 amp per hour x 24= 2.4 ah per day times 7 =19 ah per week x 4 weeks = 76 ah in 4 weeks. Not place in the under the step battery compartment for a knife switch.
Old 09-16-2015, 09:24 PM   #5
Kenny kustom's Avatar
These are common in automotive.
Easy to install and should fit.
Name:   ImageUploadedByForest River Forums1442456682.969522.jpg
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-17-2015, 12:05 AM   #6
This is what I use for the main battery disconnect. It connects inline on the battery cable.
12V CAR Stereo Audio Current Circuit Breaker Inline Fuse Protector 100Amp 100A | eBay
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 09-17-2015, 07:04 AM   #7
A circuit breaker is not meant to be manually tripped on a regular basis.
Not sure how often you trip it..
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 09-17-2015, 07:49 AM   #8
2008 F350 CCSB V10
2016 Sabre 36QBOK
That's funny because that is the way we all use them at the power pedestal in campgrounds.
Les & Heidi Kramer
2010 GMC Sierra SLE & 2014 Shamrock 23IKSS
Cleveland, OH
cpd1343 is offline   Reply With Quote
Old 09-17-2015, 08:54 AM   #9
You trip the breaker, plug in, then turn it back on?
Why..
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 09-17-2015, 09:03 AM   #10
Circuit breakers are marked SWD if they are designed to be used as a switch.
SWD - switch duty. Usually used for fluorescent lighting.
2008 F350 CCSB V10
2016 Sabre 36QBOK
battery
