07-17-2017, 08:02 AM
#21
pop the top on your old battery and fill with distilled water to the bottom of the ring...
that will add some capacity...
2014 Shamrock 183
07-17-2017, 08:39 AM
#22
Batteries are Maintenance Free !!!
Has no removal caps ???
07-17-2017, 08:55 AM
#23
Maintenance free are not good batteries the have if it is always plugged in.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
07-17-2017, 08:58 AM
#24
Interesting !!!
Maybe if I replace them I should @ something else ???
07-17-2017, 09:07 AM
#25
Unless they are Optima maintenance free, I would not use them. I am on my 6th season with my Interstates, I check the water in them 2 times during the season and add appropriately, still going strong. The chargers on these campers will boil let water inside them and then the water level gets low.
Scott & Vicki
2021 4 reserved
07-17-2017, 09:24 AM
#26
Maybe that is what has happen ???
I am showing over 13 V and well over 12v when I test them with load tester !
They just don't seem to be holding the charge very long,,, we have only boondock twice in the last 2 years,,, for one day & one night,,, batteries have died both times !!! This year I used the Genny to put slides out,,, and we watched TV for just over 1 hour before the died !!!
Maybe I am expecting too much ???
07-17-2017, 09:30 AM
#27
They should last longer than that, is your TV a 12 volt tv? If you have a generator, use that to charge them. Somehow it seems like something is draining them to go dead that quick
Scott & Vicki
2021 4 reserved
07-17-2017, 09:39 AM
#28
Yes TV is 12v,,, I agree with something draining them ???
Drained them to the point I had to start MH,,, so I could start Genny !!!
Not willing @ this time to spend a lot of $$$ to find out what it might be !!!
As I said we only boondock 1 day a year,,, so I will just try to keep Genny's Pic 0 Crap Carb clean !!!
