Originally Posted by micro_jul
I apologize for not being clear. I don't know the proper terminology for any of this. We tested the batteries with the multimeter. That is where the 80 percent figure came from. I guess saying the battery switch is turned on is incorrect. The batteries were connected and should have been charging. This is how we have always kept the trailer and the problem only started when we replaced the batteries. We took the batteries to the place where we bought them and they tested the batteries and said they were just a little less than fully charged. They kept the batteries to charge them and we will have them back shortly. We cleaned the connections around the batteries. We will see if that fixes the problem.
Don't worry about using the proper terminology. As long as you can convey what you mean we'll help you figure out the terminology as you go.
We normally look for actual voltage numbers when we ask for readings. so something like 12.5 volts would be expected and not 80%.
Saying the battery switch is turned on may be correct, if you're talking about the battery disconnect. If it was on (I prefer closed) then the batteries should be charging when plugged into shore power.
Now for the part I highlighted! We see problems a lot when people unhook and rehook or replace batteries. A lot of times they inadvertently get connected backwards even if for an instant. That blows the reverse polarity fuses in the converter, and then the batteries don't get recharged. Do you know where your converter is? Do you know where the power panel is?
Another thing replacing the battery(s) sometimes does is trip the resettable fuse near the battery(s). It's usually under to tongue or on the frame of the RV.
